O2 sensor
I just bought a DC header for my 95 Civic HB with D16 motor.
The DC header o2 sensor hole is at the end and I think my o2 sensor wire is going to be short. Do I need to add a wire in order for me to connect the o2 sensor?
Any suggestion is appreciated.
Thanks.
Thanks.
Just lengthen the four wires so it will reach the O2 location on your new header. Make sure you solder the wire/insulate with shrink tubing instead of just cutting it and taping the wires together. If you cut corners...I'm sure you will be posting up another thread on why your check engine light is on or why your ECU 15A fuse keeps blowing.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by t0p_sh0tta »</TD></TR><TR><TD CLASS="quote">Which D16 motor do you have?
If your cat is attached directly to the exhaust manifold, you will have to extend the wires.</TD></TR></TABLE>I'm sure he's talking about a D16z6.
buy an extension from http://www.casperselectronics.com
theyre quite nice and then you dont have to worry about connections failing from your solder job
mugenpovver
Feb 16, 2008 12:56 PM
