sway bar/LCA question
Old Apr 15, 2002 | 02:25 PM
VegasVTEC's Avatar
Default sway bar/LCA question
As you may know, the 99 EX does not come with a rear sway bar. I have considered purchasing either a Skunk2 22mm, or a progress 22mm. My question is as follows: Should I spend a few more bucks on 2 new LCA's from an SI which have the threaded bolt hole to make the sway bar connection more solid, or should I just use the bolt on kit which is included in each respective kit? Your thoughts are appreciated.
1.5Slowmatic
Suspension & Brakes
May 7, 2009 11:28 AM
96 GSR-T
Suspension & Brakes
Mar 11, 2008 07:21 PM
NTGR8D
Nov 30, 2003 11:50 AM
crazy_ham
Apr 6, 2003 08:59 AM
Briman2021
12
Jul 26, 2002 07:28 AM
