Ls/vtec bogging
Old Jun 7, 2006 | 12:51 PM
faSHOwidIT's Avatar
Default Ls/vtec bogging
From 8k-9k rpm the motor bogs, like it's hesitating to climb from 8k-9k. I changed the fuel filter so far and tried another ignitor. I think the other ignitor was bad becaue the tach was a bit jumpy. Im going to try someone elses dizzy next. what do you guys think it can be?
Old Jun 7, 2006 | 12:55 PM
B18cHatch06's Avatar
Default Re: Ls/vtec bogging (faSHOwidIT)
injectors might be maxing out if the setup is built enough
Old Jun 7, 2006 | 01:09 PM
pomansouth01's Avatar
Ginger Kid
put it on the wideband and see what the af is doing, my bet is that your fuel system isnt keeping up or maybe your cam isnt big enough...
Old Jun 7, 2006 | 01:13 PM
Slamaccord's Avatar
Default Re: (pomansouth01)
Whats your setup. The more details you give, the easier it is for us to come up with a scnerio.
Old Jun 9, 2006 | 11:59 AM
faSHOwidIT's Avatar
Default Re: (Slamaccord)
usdm itr pistons, itr head, m22 cams, rmf header, aebs manifold, 70mm throttle body. It never used to do it, it just started doing it. It might of started doing it after the motor got hot a little bit. But it's already dyno tuned so a/f is straight. Injectors are 270cc RC. Doubt they are maxing out.
Old Jun 10, 2006 | 01:38 AM
faSHOwidIT's Avatar
Old Jun 10, 2006 | 08:14 AM
b20vtech's Avatar
Default Re: (faSHOwidIT)
270cc are fine, i had 270cc on my old lsvtec set up and i was using ctr pistons and they dint max out.....
Old Jun 10, 2006 | 01:29 PM
faSHOwidIT's Avatar
Default Re: (b20vtech)
help
Old Jun 10, 2006 | 01:51 PM
Junkiii Ek's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by faSHOwidIT &raquo;</TD></TR><TR><TD CLASS="quote">usdm itr pistons, itr head, m22 cams, rmf header, aebs manifold, 70mm throttle body. It never used to do it, it just started doing it. It might of started doing it after the motor got hot a little bit. But it's already dyno tuned so a/f is straight. Injectors are 270cc RC. Doubt they are maxing out.</TD></TR></TABLE>
do u have a stock feul pump?
Old Jun 10, 2006 | 05:48 PM
faSHOwidIT's Avatar
Default Re: (Junkiii Ej)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Junkiii Ej &raquo;</TD></TR><TR><TD CLASS="quote">
do u have a stock feul pump?</TD></TR></TABLE> yes. but it all worked out before. Stock fuel pump should be good to 250-300hp right?
Old Jun 10, 2006 | 06:23 PM
Junkiii Ek's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by faSHOwidIT &raquo;</TD></TR><TR><TD CLASS="quote"> yes. but it all worked out before. Stock fuel pump should be good to 250-300hp right?</TD></TR></TABLE>
tell you the truth, i've always used an walbaro pump..so i couldnt tell you
Old Jun 10, 2006 | 07:16 PM
Dat1BVtecN's Avatar
ECU!!!
Old Jun 11, 2006 | 06:15 PM
faSHOwidIT's Avatar
Default Re: Ls/vtec bogging (Dat1BVtecN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dat1BVtecN &raquo;</TD></TR><TR><TD CLASS="quote">ECU!!!</TD></TR></TABLE> i will be trying that soon. how does the ecu go bad?
Old Jun 11, 2006 | 06:43 PM
JDMlyfestyle's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by faSHOwidIT &raquo;</TD></TR><TR><TD CLASS="quote"> i will be trying that soon. how does the ecu go bad?</TD></TR></TABLE>
My guess is either your Fuel Pump isnt keeping up or you need some Ignition tuning in the high RPM's
Old Jun 12, 2006 | 09:40 PM
faSHOwidIT's Avatar
Default Re: Ls/vtec bogging (JDMlyfestyle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlyfestyle &raquo;</TD></TR><TR><TD CLASS="quote">
My guess is either your Fuel Pump isnt keeping up or you need some Ignition tuning in the high RPM's</TD></TR></TABLE> that's the thing. i already got it tuned and it ran good before. it all started happening after it overheated a little.
Old Jun 12, 2006 | 10:09 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by faSHOwidIT &raquo;</TD></TR><TR><TD CLASS="quote"> that's the thing. i already got it tuned and it ran good before. it all started happening after it overheated a little.</TD></TR></TABLE>
Have you checked the spark plugs and wires?
99 eg
Nov 10, 2011 06:00 PM
thanhzz
Aug 28, 2011 10:10 PM
Grand
25
Jul 7, 2005 02:53 PM
Shane54
Oct 5, 2004 11:16 AM
Combustion Contraption
15
May 3, 2004 05:07 AM
