B16 in 1st gen crx-in progress need help with fuel and vaccum connections
Old Apr 15, 2002 | 01:05 PM
slownslc's Avatar
Default B16 in 1st gen crx-in progress need help with fuel and vaccum connections
Please post any pics you have of the engine bay. I would like to see the connections coming off the intake manifold.
HELP!
Old Apr 15, 2002 | 07:00 PM
tinkerbell's Avatar
Default Re: B16 in 1st gen crx-in progress need help with fuel and vaccum connections (slownslc)
which connections in particular?
(also try doing a search on 'vacuum diagram')
t..
Old Apr 15, 2002 | 07:56 PM
rainforest's Avatar
Default Re: B16 in 1st gen crx-in progress need help with fuel and vaccum connections (tinkerbell)
yeah there is only coolent to the bottom of the tb.
fpr vacume line front right of the manifold..
pcv line (midddle of intake manifold)
and brake booster( back of manifold).
Old Apr 16, 2002 | 09:04 AM
slownslc's Avatar
Default Re: B16 in 1st gen crx-in progress need help with fuel and vaccum connections (rainforest)
Thanks, any pics from the map sensor.
Old Apr 16, 2002 | 04:13 PM
tinkerbell's Avatar
the MAP sensor should attach to a small hose attached to one of the metal tubes that run along the top of the back of the plenum and attaches to another small hose that plugs into the top of the throttle body...
this may help
t..
Old Apr 16, 2002 | 06:40 PM
tinkerbell's Avatar
also this pic of the MAP sensor and my beautiful surge tank/fuel system:
HTH,
t..
Old Apr 17, 2002 | 06:31 AM
slownslc's Avatar
The pics didn't work. Can you try it again please.
Old Apr 17, 2002 | 06:52 AM
slownslc's Avatar
Now they work, thanks.
Old Aug 10, 2004 | 08:18 PM
B16CRXT's Avatar
Can someone please show me where this vaccum line is going? It isnt connected to anything on mine...
Old Aug 11, 2004 | 03:45 PM
calgone47's Avatar
It goes to the intake I think
Old Aug 11, 2004 | 07:11 PM
B16CRXT's Avatar
Default Re: (calgone47)
I have an AEM intake on mine and the only connection it has is to the valve cover. Should I buy a t fitting and connect that vaccum to another hose? IF so which one? Would it have any effect on my car for this to be disconnected?
TIA
tempsohc
Jun 19, 2011 06:06 PM
LUKE 92 GS-R
Jun 18, 2008 06:17 PM
juanchoenuncrx
Dec 26, 2007 05:03 PM
zippeay
Aug 8, 2003 02:25 PM
