00 Civic timing belt probs.
Old Jun 6, 2006 | 05:44 PM
nasirjones9mm's Avatar
Default 00 Civic timing belt probs.
yeah i've tried searching for my prob. no help tho. i hope this is a relevant forum to put it in. oh well here it is:
so when i go to start my car i hear the timing belt make noise as it goes round and round. i thought i needed a valve adjustment but that wasn't it. its def. the belt. so its only when i start it. i'll hear it make noise all the way down my driveway as i reverse out. then when i go to a higher gear it goes away. then at stoplights/signs it doesn't make noise anymore. just when i start it and back out.
how can i go about and solve my prob? any suggestions?
thanks guys!!!
Old Jun 6, 2006 | 05:48 PM
Aquafina_Powered's Avatar
Default Re: 00 Civic timing belt probs. (nasirjones9mm)
u sure its not an accessory belt?
Old Jun 6, 2006 | 05:52 PM
hondamark35's Avatar
yeah, a timing belt is going to be a whine sound...that is if it's too tight. but being a 00 model you probly still have the factory belt on there so it's not too tight. check the tension on your outer belts.
Old Jun 6, 2006 | 06:07 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: 00 Civic timing belt probs. (hondamark35)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondamark35 &raquo;</TD></TR><TR><TD CLASS="quote">yeah, a timing belt is going to be a whine sound...that is if it's too tight. but being a 00 model you probly still have the factory belt on there so it's not too tight. check the tension on your outer belts.</TD></TR></TABLE>
Old Jun 6, 2006 | 06:33 PM
-JSpecEk*9-'s Avatar
Default Re: 00 Civic timing belt probs. (Evs-One)
is it only in reverse? cuz if it is then all trans do that.
Psycho719
Sep 14, 2011 04:28 AM
Osis
Honda Civic (2001 - 2005)
Oct 15, 2007 08:23 AM
BOOSTEDgreeneg
May 25, 2005 12:51 AM
kevtec_00
Jan 19, 2005 03:30 AM
cr00klyn718
Sep 5, 2003 12:53 PM
