Weird Idle??? I need some help.
Old Jun 6, 2006 | 05:14 PM
I Like Hondas's Avatar
Default Weird Idle??? I need some help.
So I started my car up today. I dont know if it matters but its a d15vtec. And when idles it will go to 2k the drop to 1.5k then go up to 2 and back down. Normally it stops as soon as I start driving. But this time when i started driving it did the same thing and started lurching. Someone told me it was a map sensor. But i have no idea what that is. But if anyone could help me that would be fawsome.
Old Jun 6, 2006 | 06:22 PM
EF Sedan Enthusiast's Avatar
Default Re: Weird Idle??? I need some help. (I Like Hondas)
check all of your vacuum and make sure it's still snug/connected. your map might be on your throttle body or it's a stand alone unit. follow the vacuum lines coming off your charcoal canister and they should lead to firewall, top of throttle body and map sensor.
Old Jun 6, 2006 | 06:24 PM
xx89civicracer89xx's Avatar
Default Re: Weird Idle??? I need some help. (jdm_ef3)
might also be ur IAC valve
Old Jun 8, 2006 | 02:26 PM
thanks guys.
Old Jun 8, 2006 | 02:58 PM
nowentaquit's Avatar
Default Re: (I Like Hondas)
Are you throwing a code? If you are check it and go from there.
Old Jun 11, 2006 | 02:54 PM
saaron34's Avatar
Default Re: (nowentaquit)
I had a similar problem and it ended up being a messed up IAC valve. the one that came with my b18 was causing the idle to go up and down constantly like you describe. When we unplugged the IACV, the idle continued to go up and down, but much faster. Replaced with the old unit off my d16a6 intake after a good cleaning, and it works fine now.
(just so you know, coolant will be leaking out when you remove the IACV. Be prepared.)
Old Jun 11, 2006 | 03:34 PM
johnjw's Avatar
Default Re: Weird Idle??? I need some help. (xx89civicracer89xx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xx89civicracer89xx &raquo;</TD></TR><TR><TD CLASS="quote">might also be ur IAC valve</TD></TR></TABLE>
100%
Old Jun 11, 2006 | 05:35 PM
d16efsedan's Avatar
Default Re: Weird Idle??? I need some help. (johnjw)
could be your rotor also,i had this problem and popped the dizzy cap off my my rotor was broke
Justinmnhall
22
Sep 6, 2013 03:40 PM
BKKloppenborg
Apr 7, 2009 09:26 PM
crfr230
Apr 24, 2007 07:48 PM
mikeunreal
Oct 26, 2005 05:31 PM
paul93sir
Feb 5, 2004 11:26 AM
