CTR intake cam on stock B18C1...is it possible to use?????
Old Jun 6, 2006 | 04:37 PM
1JDMDOMINICAN's Avatar
Default CTR intake cam on stock B18C1...is it possible to use?????
Just wanted to know if it was possible to drop a CTR intake cam on a stock B18C1 and run it using my stock GSR exhaust cam? A deal was gonna go thru for some CTR cams, but the guy backed out so I'm considering just buying the CTR intake cam from JHPUSA.com. Would I have to upgrade the valvesprings? Would I actually gain anything from it or will I just be messing up my motor?
I've heard of people using this set up, just never been able to talk to someone who has owned it before to get feedback on it.
Anyone, chime in!
Old Jun 6, 2006 | 07:22 PM
UncleD's Avatar
Default Re: CTR intake cam on stock B18C1...is it possible to use????? (1JDMDOMINICAN)
Possible? Yes. Do you hafta change the valvetrain? As long as you're not revving past stock, no.
Old Jun 7, 2006 | 07:09 AM
spooncivic1's Avatar
i had one in my old gsr swap...it worked just fine. i also had kenji make me a custom basemap and i took it to 8.5k daily no problems, on stock valvetrain
Old Jun 7, 2006 | 08:38 AM
Tuesday Club's Avatar
yes....
Old Jun 7, 2006 | 09:54 AM
b16adx's Avatar
Default Re: CTR intake cam on stock B18C1...is it possible to use????? (Tuesday Club)
Yes u can but if its COMPLETELY stock as in ecu and the crossover comes at 4400 rpms ive never been in one that didnt bog at 4400 then raise hell at 5700 rpms!
Old Jun 7, 2006 | 10:11 AM
Default Re: CTR intake cam on stock B18C1...is it possible to use????? (b16adx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16adx &raquo;</TD></TR><TR><TD CLASS="quote">Yes u can but if its COMPLETELY stock as in ecu and the crossover comes at 4400 rpms ive never been in one that didnt bog at 4400 then raise hell at 5700 rpms!</TD></TR></TABLE>
mine did...it fell on its face from 4400-5700
Old Jun 8, 2006 | 06:03 AM
Default Re: CTR intake cam on stock B18C1...is it possible to use????? (spooncivic1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spooncivic1 &raquo;</TD></TR><TR><TD CLASS="quote">
mine did...it fell on its face from 4400-5700</TD></TR></TABLE>
So what would you recommend I do?
Old Jun 8, 2006 | 06:40 AM
Big Bang's Avatar
do it, just get it tuned
Old Jun 8, 2006 | 02:57 PM
quicksilver1689's Avatar
i ♥ snails
Why not get the matching ITR/CTR exhaust cam? GSR cams arent too bad but if ur upgrading then do it fully.
Old Jun 8, 2006 | 06:13 PM
i would also recommend a single stage IM along with a chipped ecu
Old Jul 16, 2006 | 07:10 PM
GranadaTeg's Avatar
more opinions
Old Jul 26, 2006 | 09:17 AM
GranadaTeg's Avatar
more opinions.
Old Jul 26, 2006 | 11:08 AM
black_EM1's Avatar
Community Builder
Community Influencer
Default Re: CTR intake cam on stock B18C1...is it possible to use????? (Slo Cord)
It's a nice setup if you get it tuned slightly
Old Jul 26, 2006 | 04:00 PM
DC2SIR-G's Avatar
* B A N N E D *
Default Re: CTR intake cam on stock B18C1...is it possible to use????? (black_EM1)
my friend had that set up in his GSR along with a skunk2 intake manifold and a chipped p28.. pulls real nicely
Old Sep 10, 2006 | 11:10 AM
daver's Avatar
did you end up doing this mod? I'm thinking about it myself, the intake cam only. I'd do both, but personally i'd be worried about putting the exhaust cam in with only the gsr single exhaust springs. So then i'd be in for spring swapping and expensive specialty tools and a lot of hassle. Thats my reasoning.
I think the consesus around here is about an 8hp gain with the intake cam only, tuned.
d
Old Sep 10, 2006 | 12:02 PM
iH8RICERZ's Avatar
Default Re: CTR intake cam on stock B18C1...is it possible to use????? (clean rice)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clean rice &raquo;</TD></TR><TR><TD CLASS="quote">Possible? Yes. Do you hafta change the valvetrain? As long as you're not revving past stock, no.</TD></TR></TABLE>
I have a ctr intake cam in my basically stock gsr.... and with the stock ecu, you won't really notice any difference. Getting your motor tuned is key in all situations!
Old Sep 10, 2006 | 05:00 PM
2'z kuztoms's Avatar
From: Streets of Sacramento...But now living in So Cal, usa
you'll be alright. i know people who rev there motor to 8500 on stock valve train with ctr cams no problem
Old Sep 13, 2006 | 04:54 PM
daver's Avatar
Default Re: (2'z custom colors)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2’z custom colors &raquo;</TD></TR><TR><TD CLASS="quote">you'll be alright. i know people who rev there motor to 8500 on stock valve train with ctr cams no problem</TD></TR></TABLE>
your frends may be having advanced wear and they won't even know it unless they take the valve train apart and measure tolerances.
In all my itr cam research, i found only one guy who actually did this and he found that all his exhaust valves had slight bends in them (8200 redline). that stayed in my head as perhaps important.
d
Old Sep 13, 2006 | 04:56 PM
black_EM1's Avatar
Community Builder
Default Re: (daver)
Good to know. Thanks.^^^^
Old Sep 13, 2006 | 05:38 PM
trinituner's Avatar
I had my GSR tuned to 168/123 with VTEC at 5800, redline at 8200rpm with stock valve train. Next step is to upgrade to a better valve train with bigger cams, but this combination pulls nice.
Old Sep 13, 2006 | 07:09 PM
daver's Avatar
Default Re: (trinituner)
pretty good numbers, was that with the stock gsr intake manifold?
Old Sep 14, 2006 | 03:58 PM
trinituner's Avatar
Default Re: (daver)
Thanks, I am using the S2 pro series IM with a STR 65mm throttle body, but my header is the stock one and it is really holding it back. Im saving for the Rage header...lol
Old Apr 24, 2007 | 04:17 PM
mastakmk's Avatar
yeah, im running into the same situation here. got a b18c1 just got a valve job done and new seals. wanted to go with badder cams. later on i wish to turbo possibility of a year or 2. i got s200 as well. s2 pro IM and TB, exhaust header intake, but stock bottom end and stock valvetrain. dunno if it would be better to go with both ctr intake and exhaust cams, just the ctr intake cam, or with the skunk 2 stage 2 cams. i do not plan on reving past 8k as i do not wish to f up my valves, if i got both ctr cams would it eliminate the slight bending of the valves or no chance? please anyone with helpful information, i need this back on the road in 3 weeks. fully taken apart due to an accident back in nov. lol i got massive amount of pics ill post up when finished. fixed in my garage. thanks a lot guys.
edit: well with the s2 stage 2 cams i would need to upgrade the valvetrain so im looking more at the ctr's. as some rice burner flys past my window. lol
forget it. i said b4 ima just upgrade all at once. f dis
Modified by mastakmk at 6:39 PM 4/24/2007
Modified by mastakmk at 10:48 PM 4/25/2007
Modified by mastakmk at 10:49 PM 4/25/2007
94ls
Apr 8, 2005 02:57 PM
theslugbug
Jun 20, 2004 08:34 AM
gsr-2nr
Feb 28, 2004 02:43 AM
Unsung
May 22, 2002 08:56 AM
Weslay
Mar 4, 2002 10:16 AM
