Stripped Fuel Rail stud holes.... need some sugestions?
Old Jun 6, 2006 | 03:51 PM
import810's Avatar
Default Stripped Fuel Rail stud holes.... need some sugestions?
I purchased a gsr skunk2 manifold awhile go here on HT. When it cams it had a broken brake booster nipple so I fixed that, but now I have another problem. THe fuel rail holes are stripped and now I have a fuel leak since it's not tight enough. Are there any studs that are bigger (diamerter) that I can screw in there (soft metal). I was able to screw in my brake booster with teflon for a tight seal, but can i do this with studs? Please tell me if you know of any studs that are bigger, my car has been sitting for 3 weeks.
Old Jun 6, 2006 | 07:52 PM
import810's Avatar
Default Re: Stripped Fuel Rail stud holes.... need some sugestions? (import810)
bump for answers
Old Jun 6, 2006 | 09:00 PM
Sack Master's Avatar
Either heli-coil it or put in timeserts. Then use studs not bolts and loc-tite those bitches in there. That would be your best bet.
Old Jun 7, 2006 | 08:30 AM
RHDintegXsi's Avatar
Default Re: Stripped Fuel Rail stud holes.... need some sugestions? (Sack Master)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sack Master &raquo;</TD></TR><TR><TD CLASS="quote">Either heli-coil it or put in timeserts. Then use studs not bolts and loc-tite those bitches in there. That would be your best bet.</TD></TR></TABLE>
Old Jun 7, 2006 | 11:49 AM
import810's Avatar
Default Re: Stripped Fuel Rail stud holes.... need some sugestions? (SINFULintegXsi)
any ideas which ones I need?
Old Jun 7, 2006 | 12:04 PM
__oversea's Avatar
or take it to the machine shop. i wouldnt do any getto job where fuel flows.
1greatEG
Aug 6, 2008 07:46 PM
type Gendy
Nov 13, 2007 05:41 PM
BEE1
Feb 22, 2007 11:37 AM
Charlie Moua
Oct 28, 2003 06:41 AM
Brian_92GSR
Oct 23, 2003 12:05 AM
