how to get to TDC with no t belt
Old Jun 6, 2006 | 02:57 PM
7808's Avatar
Default how to get to TDC with no t belt
i got a 93 ls that came with a broken t belt, the up arrows on the cams are pointed down, one is pointed slighty foward and down
the shop manual says rotate the crank pully so the cams are at tdc but theres no t belt how should i line everything up?
Old Jun 6, 2006 | 03:01 PM
LordAphotic's Avatar
set the crank pulley for TDC then move the cams so they are set for TDC too. theres arrows on the cam pulleys and also a small like on the side of the crank pulley that you have to line up on both the crank pulleys so you know that they are both on the same page.
Old Jun 6, 2006 | 08:48 PM
7808's Avatar
Default Re: (LordAphotic)
i got the cam gears and crank pulley figured out i think but what do you mean both crank pulleys? also which mark on the lower main crank pully should be lined up with the line on the lower cover
also does it matter which way i turn the cam gears to put them at up?
thanks
Old Jun 6, 2006 | 08:54 PM
DC2 Mang's Avatar
Default Re: (7808)
for the crank pulley there are a series of 3 small notches, two white with a red one in the middle, line the red one up to the line on the timing belf cover
as for the cams, put them so the arrows on the gears that say up are up. then look for the notches on the cam gears where the cam gears are closest and adjust the ams until they are level with eachother
after this you can install your timing belt and dont forget to tension your tensioner and you should be good to go
Old Jun 6, 2006 | 10:24 PM
7808's Avatar
Default Re: (DC2 Mang)
mine has like 4 lines on the pully, 3 together then looks like theres another like an inch or so away.. none are colored
guessi should just out it in the middle of the 3 huh
also does the pully have to be off to get the lower t belt over off? i found 2 bolts and took them out, havent took the pully off, just the nut
Old Jun 6, 2006 | 10:27 PM
DC2 Mang's Avatar
Default Re: (7808)
just use the one in the middle of the cluster of 3
Old Jun 6, 2006 | 10:41 PM
RHDintegXsi's Avatar
Default Re: (7808)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 7808 &raquo;</TD></TR><TR><TD CLASS="quote">mine has like 4 lines on the pully, 3 together then looks like theres another like an inch or so away.. none are colored
also does the pully have to be off to get the lower t belt over off? i found 2 bolts and took them out, havent took the pully off, just the nut</TD></TR></TABLE>
you need to use the white mark on the pulley..you said none are colored..it is the single one away from the other three..
the three marks closest to each other are for when you check timing.. i believe they are 14,16,and 18 degress before tdc..if you were to use the center of the three when installing the belt you will be a few teeth off
as far as getting the timing belt cover off..yes you must remove the crank pulley first
Old Jun 6, 2006 | 10:44 PM
Default Re: (SINFULintegXsi)
heres a writeup of a gsr engine but same steps...
http://www.c-speedracing.com/h...t.php
Old Jun 7, 2006 | 02:23 AM
7808's Avatar
ya thats a good write up, that and my pdf manual are the only helpers i have and its my 1st t-belt, my civic needs it next
Old Jun 7, 2006 | 06:04 AM
Sam92Teg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SINFULintegXsi &raquo;</TD></TR><TR><TD CLASS="quote">
as far as getting the timing belt cover off..yes you must remove the crank pulley first</TD></TR></TABLE>
This is correct!!!
Old Jun 7, 2006 | 08:59 AM
ThePro's Avatar
Default Re: (Sam92Teg)
I know you probably know this but I knew an idiot who swapped an LS into his Civic and when setting the timing set his cam gears arrow straight up in relation to the floor of the garage. Which screwed things up.
The engine sits slightly angled and the cam gears need to be straight up in relation to the engine.
Old Jun 7, 2006 | 01:48 PM
7808's Avatar
does itmatter which way i rotate the cams to line them up? someone told me theres a right and wrong way
Old Jun 9, 2006 | 07:21 AM
ThePro's Avatar
Default Re: (7808)
I don't know how to answer that. But I'd be willing to bet that rotating them in the same direction the engine would normally turn would be a safe way to do it.
foolsforever
11
Aug 9, 2018 05:08 PM
jefsese
Jul 17, 2008 12:19 PM
M2S~Jaime
Jun 12, 2008 02:21 AM
RTW DC2R
May 23, 2005 10:33 AM
crxzcracer
Apr 9, 2004 08:05 AM
