looking for a small 4 channel amp...
Old Jun 6, 2006 | 10:31 AM
sol2hatch's Avatar
Default looking for a small 4 channel amp...
anyone have a recommendation for a good 4 channel amp that will power my front and rear speakers? 5.25" Infinity kappas in the rear and i plan on some Infinity kappa perfect components in the future for the front. So the amp needs to have decent power. I want a small amp because i dont have much room anywhere in my hatch. The rear is taken up with my sub+box+huge amp already, so i was looking at an amp to put under my passenger seat maybe.
Old Jun 6, 2006 | 11:07 AM
vivaladan89's Avatar
i was searching all over and cant find it, i was looking for a really small alpine amp that had a digital meer on the outside. i saw it at the car audio shop by my house but its pricey.but i did find this http://www.woofersetc.com/inde...=3730
Old Jun 6, 2006 | 11:41 AM
GSteg's Avatar
How much do you want to spend? I might have something for you.
Old Jun 6, 2006 | 04:11 PM
incubus's Avatar
Default Re: (GSteg)
check the dimensions on a kicker zx350.4 it is 40x4rms. dont bother with the perfect component set there are far better things out there for about the same price. I had one before and it was mediocre at best. Look into mb quart RCE-216s retails for about $300-330.
Old Jun 6, 2006 | 08:03 PM
sol2hatch's Avatar
Default Re: (GSteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSteg &raquo;</TD></TR><TR><TD CLASS="quote">How much do you want to spend? I might have something for you.</TD></TR></TABLE>
i am not sure how much i want to spend. Maybe $100 for something used. Depends on what you have. What do you have?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by incubus &raquo;</TD></TR><TR><TD CLASS="quote">check the dimensions on a kicker zx350.4 it is 40x4rms. dont bother with the perfect component set there are far better things out there for about the same price. I had one before and it was mediocre at best. Look into mb quart RCE-216s retails for about $300-330.</TD></TR></TABLE>
Whats wrong with the perfect components? I can get a really good deal, to the tune of $160 for a pair of perfect components. I get a real good deal on all of infinitys/JBLs stuff. Did you have them powered enough? JW
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vivaladan89 &raquo;</TD></TR><TR><TD CLASS="quote">i was searching all over and cant find it, i was looking for a really small alpine amp that had a digital meer on the outside. i saw it at the car audio shop by my house but its pricey.but i did find this http://www.woofersetc.com/inde...=3730</TD></TR></TABLE>
that is pretty nice, just about exactly what I want. Kinda wanted to spend less though, maybe find a used one. Not sure what I think about alpine amps though. Dont know much about them.
Old Jun 8, 2006 | 03:26 PM
8520's Avatar
Get the mrpf250. Still compact and still decent sound.
Alpine amps tend to not make tons of power though
Old Jun 8, 2006 | 04:57 PM
fcm's Avatar
fcm
Old Fart
Default Re: looking for a small 4 channel amp... (sol2hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sol2hatch &raquo;</TD></TR><TR><TD CLASS="quote">anyone have a recommendation for a good 4 channel amp that will power my front and rear speakers? 5.25" Infinity kappas in the rear and i plan on some Infinity kappa perfect components in the future for the front. So the amp needs to have decent power. I want a small amp because i dont have much room anywhere in my hatch. The rear is taken up with my sub+box+huge amp already, so i was looking at an amp to put under my passenger seat maybe. </TD></TR></TABLE> Here are some used JL Audio 300/4... http://search.ebay.com/search/...soo=1
A descent 4ch amp for around $100 is not going to be easy to find, I have installed more then a few 300/4 under the front seats of some Honda/Acura's.
The JL amp should do the job pretty good. 94
Old Jun 8, 2006 | 08:19 PM
sol2hatch's Avatar
Default Re: looking for a small 4 channel amp... (fcm)
i can get a JBL 4 channel amp that pushes 60 watts RMSx4 for $72 brand new. I think i will just get that. or maybe an infinity 111 watts RMSx4 amp for $132, but i dont think i need that much power. What do you guys think?
BTW: i get a really good discount, that is how i got those numbers
Old Jun 8, 2006 | 11:30 PM
8520's Avatar
I'd go with the infinity, but even with whatever discount you get, I doubt it's truly 111rmsx4.
Old Jun 8, 2006 | 11:39 PM
sol2hatch's Avatar
Default Re: looking for a small 4 channel amp... (a_s_ol_)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by a_s_ol_ &raquo;</TD></TR><TR><TD CLASS="quote">I'd go with the infinity, but even with whatever discount you get, I doubt it's truly 111rmsx4.</TD></TR></TABLE>
why do you doubt it? that is what the specs say. Is infinty bad about posting higher than actual RMS???
Old Jun 8, 2006 | 11:44 PM
8520's Avatar
Because I have employee discounts and the dollar per watt there is pretty abnormal. I certainly won't knock infinity amps cause I've only heard their speakers/subs. From what I've heard -
Old Jun 9, 2006 | 12:13 AM
GSteg's Avatar
The infinity amp does 111w per channel, though it was probably rated when one channel was in use. I doubt the power supply has enough power for 111w with 4 channels driven.
Old Jun 9, 2006 | 07:28 AM
sol2hatch's Avatar
Default Re: (GSteg)
well, even if the infinity amp only pushes 80 or 90 rmsx4, that is plenty for my application. So I think I will just get that amp. Hope it fits under my seat! its dimensions are 12"x 15"x 2-11/16" (LxWxH)
Old Jun 9, 2006 | 07:57 AM
fcm's Avatar
fcm
Old Fart
Default Re: (GSteg)
According to the specs the Infinity REF7541A CEA rating is 4x111W RMS into 4 ohms @ 14.4V, 4x139W RMS into 2 ohms @ 14.4V and 2x278W RMS into 4 ohms @ 14.4V and a max draw of 85A, however the amp comes with 2x30A fuses, [60A] and recommends 8ga power cable, it sure looks like the numbers are fudged someplace.
I will say I have heard a REF7541A installed, driving Alpine SPX-177Rs, [front] and SPX-17MBs in the rear, both sets custom installed in a Civic, I must say I was impressed, lots of power and dynamic headroom, and very good SQ. 94
RyanWhite
Audio / Security / Video
May 22, 2015 09:20 PM
Gouki133
Oct 20, 2006 11:46 AM
Corporation
May 7, 2006 11:19 AM
Iomega01
Aug 27, 2005 09:54 AM
EVIL_AWD
13
Jul 18, 2003 12:14 PM
