Will this damage my engine??????
Old Jun 6, 2006 | 08:23 AM
a12rnulfo's Avatar
Default Will this damage my engine??????
I have a B16a in a 91 LS and i have been running my car with the check engine light on for almost 2 years now. If i have caused damage to my engine what's the worst that can happen?
The code it's throwing is for the O2 sensor.
Old Jun 6, 2006 | 08:53 AM
bluemax189's Avatar
Default Re: Will this damage my engine?????? (a12rnulfo)
your wasting alot of gas
Old Jun 6, 2006 | 10:04 AM
a12rnulfo's Avatar
Default Re: Will this damage my engine?????? (bluemax189)
Beside that problem, anything else???????????????????
Old Jun 8, 2006 | 10:35 PM
Raw B's Avatar
Running rich will clog you cat and in turn create extra backpressure, robbing you of HP
Old Jun 8, 2006 | 10:56 PM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Will this damage my engine?????? (Raw B)
Buy a damn O2 sensor. Your car must run like garbage.
Old Jun 9, 2006 | 02:10 AM
phyzJunkieCivic's Avatar
From: Dont You Just Love Lynn Cops, Boston MA, USMA
Maddddd money going out of your exhaust!
Old Jun 9, 2006 | 05:17 AM
redface's Avatar
Default Re: (phyz)
like he said only possible clogged cat and the extra gas money your throwin away you would have been better off buyin an 02 sensor and the fact that the cars in limp mode now and runnin like total garbage
Old Jun 9, 2006 | 03:08 PM
Spec...G@rage's Avatar
If youve got an O2 code, Technically you might not be wasting gas. You might be running lean as all hell. Is your engine knocking at all? PING!
Back probe the o2 sensor while the car is running and get a voltage drop with a dvom- Should be around .6-.7 If it is above that then your wasting a buncha gas, If its below that your engine is prolly knocking like a b@stard and your running lean as hell..
Old Jun 10, 2006 | 05:06 AM
redface's Avatar
Default Re: Will this damage my engine?????? (1QcKCrX)
99% of the time when an o2 sensor goes bad the car runs rich... because it goes into limp mode for that simple reason as to not damage the engine and run lean therefore it runs rich
Old Jun 10, 2006 | 06:05 AM
98vtec's Avatar
moderator emeritus
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Raw B &raquo;</TD></TR><TR><TD CLASS="quote">Running rich will clog you cat and in turn create extra backpressure, robbing you of HP</TD></TR></TABLE>
not only that, but running really rich for 2 friggin years has possibly done ring damage since too much fuel has the possibility to wash all the oil off the cylinder walls and makes the rings get all ate up then you lose compression.
Old Jun 10, 2006 | 02:01 PM
User 5426's Avatar
Default Re: Will this damage my engine?????? (98vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">
not only that, but running really rich for 2 friggin years has possibly done ring damage since too much fuel has the possibility to wash all the oil off the cylinder walls and makes the rings get all ate up then you lose compression.</TD></TR></TABLE>
Old Jun 10, 2006 | 07:58 PM
JeffBro's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">not only that, but running really rich for 2 friggin years has possibly done ring damage since too much fuel has the possibility to wash all the oil off the cylinder walls and makes the rings get all ate up then you lose compression.</TD></TR></TABLE>
This is true. The extra fuel goes straight into the oil and gas dissolves oil( not good).
Old Jun 10, 2006 | 08:27 PM
Jim Truett's Avatar
Default Re: Will this damage my engine?????? (redface)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redface &raquo;</TD></TR><TR><TD CLASS="quote">99% of the time when an o2 sensor goes bad the car runs rich... because it goes into limp mode for that simple reason as to not damage the engine and run lean therefore it runs rich </TD></TR></TABLE>
It doesn't go into limp mode, it stays in open loop mode. The stock maps are tuned around 12:1 at 14" of vacuum and less, so you are wasting fuel, run the risk of excessive cylinder wall wear, and could be causing your oil to break down faster.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JeffBro &raquo;</TD></TR><TR><TD CLASS="quote">
This is true. The extra fuel goes straight into the oil and gas dissolves oil( not good).</TD></TR></TABLE>
And that also creates acids which etch bearings.
Old Jun 11, 2006 | 08:01 AM
a12rnulfo's Avatar
Default Re: Will this damage my engine?????? (Jim Truett)
The problem with "just put a new o2 sensor" is that i have a pre obd engine, and the shop that did the wiring on my car said they accidently throw the stock headers that came with my jdm b16a away. So good thing for me that a friend of mine happen to have a usdm b16a1 and let me have his stock headers . So i did notice that the o2 sensors are different and i have no idea on getting this problem fixed. I have a set of DC headers for a b16a that has a o2 sensor already on it but it's a 4 wire and i believe my engine came with 2 single wire o2 sensor's. Do i need to change to obd1 or just buy a set of pre-odb headers, or is it possible to use my DC headers???????????
iluvmy2000civicex
Apr 17, 2008 10:43 PM
You Know I Got SOL!
Jul 3, 2006 10:13 AM
JDM_Andrew
Aug 29, 2005 11:11 AM
crxtreme27
Mar 26, 2003 07:04 AM
MOD5CSi
Aug 6, 2001 08:54 PM
