Another Swap not starting.. :-(
Old Jun 5, 2006 | 07:51 PM
mcgee*'s Avatar
Cigarette Squad
Default Another Swap not starting.. :-(
K well just did the D15b swap, before i start elimanating *spelling* what could be wrong im going to ask this...
My ecu is getting chipped wouldnt be here till wednesday so im running a P06 ecu and vtec isnt wired up to the harness either ("maybe" this is why its not working) i donno...
But heres my situation...
I put key in, i heard fuel pump.. then crank.. engine turned but didnt start..tryed second time same thing happen.. then the radiator fan turned on for a sec then turned off.. Third time it wouldnt even turn over, its just dead.. so before it got to dark out.. i checked my lights and all that i got good battery charge.. and no fuel didnt get to the spark plugs.. so well help me start elimating my choices for the a.m..thanks
Old Jun 5, 2006 | 07:53 PM
nekoabandoned's Avatar
Default Re: Another Swap not starting.. :-( (McGeeTM)
you need spark!
check your fuses first
and do the screw driver thing
Old Jun 5, 2006 | 07:54 PM
JDMlyfestyle's Avatar
most likely your ICM or just your whole distributor
Any CEL?
Old Jun 5, 2006 | 07:57 PM
mcgee*'s Avatar
Cigarette Squad
Default Re: (JDMlyfestyle)
will the d15b7 dizzy work?
checked fuses (all look good) also.. i noticed on the intake manifold i got their isnt a sensor where the d15b7 had one which connected to black canister
The sensor is located:
Looking forward.. Behind Top Right
mcgee*'s Avatar
Cigarette Squad
Default Re: (McGeeTM)
no CEL's
Old Jun 5, 2006 | 07:59 PM
evap purge valve
but you dont need that! , so just block that off.
Old Jun 5, 2006 | 08:01 PM
mcgee*'s Avatar
Cigarette Squad
Default Re: (nekoabandoned)
eh?? explain that to me..lol
Old Jun 5, 2006 | 08:02 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlyfestyle &raquo;</TD></TR><TR><TD CLASS="quote">most likely your ICM or just your whole distributor
Any CEL?</TD></TR></TABLE>
mcgee*'s Avatar
Cigarette Squad
why the ur scaring me with it!
Old Jun 5, 2006 | 08:04 PM
MassScene's Avatar
I spend over an hour one time trying to get a motor started. It ended up being there wasnt enough grounds hooked up. dont over look em.
Old Jun 5, 2006 | 08:05 PM
mcgee*'s Avatar
Cigarette Squad
Default Re: (MassScene)
checked grounds.. i think (one on tranny and one on head) anymore?
btw whats ICM stand for?
Old Jun 5, 2006 | 08:06 PM
jays93eg6's Avatar
Hey man where in Columbia are you? Maybe I could stop by and take a look. I have swapped a few motors. Hit me with a PM and let me know.
Old Jun 5, 2006 | 08:08 PM
ICM= Ignition Control Module.
mcgee*'s Avatar
Cigarette Squad
Default Re: (jays93eg6)
pmed
Old Jun 5, 2006 | 08:09 PM
mcgee*'s Avatar
Cigarette Squad
just remembered.. the spring inside the dizzy was bent too, would that be a problem?
Old Jun 5, 2006 | 08:11 PM
spring makes contact to the Cap to distribute the spark so if that was not making contact then yes that could be a problem.. it must be straight
if you look inside the cap you will see one pin out of the circle prolly off in the corner or something.. the spring must make contact with that.
to test your ICM and coil use my write up i did a while back
https://honda-tech.com/zerothread?id=1430824
Old Jun 5, 2006 | 08:15 PM
mcgee*'s Avatar
Cigarette Squad
k let me go check this out right now
Old Jun 5, 2006 | 08:35 PM
mcgee*'s Avatar
Cigarette Squad
wasnt the spring thing.. switched it out.. still dead.. didnt hear fuel pump start up either.. ill check the ICM in the morning
Old Jun 5, 2006 | 08:38 PM
Fuel pump not priming is lamost garuntee'd to be your main relay or the obvious a dead fuel pump
Old Jun 5, 2006 | 08:42 PM
mcgee*'s Avatar
Cigarette Squad
fuel pumped worked 4 days ago.. right before i did swap..
where's main relay located? isnt it the fuse located in the engine bay?
Old Jun 5, 2006 | 08:54 PM
UrbanEh's Avatar
The main relay is right by the hood pop, under the dash. 10mil bolt and a plug. I hate these types of problems. You can take the case off the relay to check it. Theres two tabs to take it apart, look for burnt or weak connections. Good luck
Old Jun 5, 2006 | 08:55 PM
mcgee*'s Avatar
Cigarette Squad
Default Re: (UrbanEh)
i knew that.. i dont even knew why i asked..lol
Old Jun 5, 2006 | 08:58 PM
mcgee*'s Avatar
Cigarette Squad
going to go check it out now..be back for results.
Old Jun 5, 2006 | 09:05 PM
bmoua's Avatar
check out your dizzy...if thats koo then check your sparks...if your getting some sort of spark, and still can't start it...its got to be your timing...
Old Jun 5, 2006 | 09:07 PM
mcgee*'s Avatar
Cigarette Squad
Default Re: (bmoua)
k im gunna do this 2morrow i cant see **** even with this bright *** light in my face...
