Washer / Bolt trick does work for rear camber! PROOF!!
Old Apr 15, 2002 | 10:50 AM
Fuster_Cluck's Avatar
Default Washer / Bolt trick does work for rear camber! PROOF!!
Here is my printout from today......
(Rear passenger side was adjusted only)
And this one is when I just got the front done 5 days before:
(front were both adjusted since I have the skunk2 camber kit in)
(rear was to much, so I had to install washers / longer bolts)
Went from over 3 degrees down to about 1 1/2 degrees which falls under the 2 degrees specified
That's 3 3/8th galvanized washers on each 45mm length bolt.
Finally my drop is done :sleep:
Thanks to all for the help from choosing the camber kit, to purchasing the GC's, the shops to deal with, to installing it all!!!
scansel912
Honda Civic (2001 - 2005)
28
Sep 5, 2009 08:10 PM
brianmcivics
Suspension & Brakes
Feb 6, 2008 07:56 AM
Dub C
Feb 18, 2006 04:52 PM
jdmaccord23
Jan 27, 2005 07:58 PM
