Skunk2 Pro 1's or Skunk 2 Stage 2's???
Old Jun 5, 2006 | 06:58 PM
Its that kidfolk's Avatar
Default Skunk2 Pro 1's or Skunk 2 Stage 2's???
thanks guys
I figured out my solution!
Modified by Its that kidfolk at 9:01 PM 6/6/2006
Old Jun 5, 2006 | 07:11 PM
MR_Ek4's Avatar
Default Re: Skunk2 Pro 1's or Skunk 2 Stage 2's??? (Its that kidfolk)
Pro 1's are very similar to the s2's beside the huge primary lobe of the pro's which will lead to more idle problems i doubt any power increase from switching from s2's to pro1's and the fact that cams have 10k shouldnt affect the performance one bit.
Old Jun 5, 2006 | 07:13 PM
Default Re: Skunk2 Pro 1's or Skunk 2 Stage 2's??? (EM1_00MRBuilt)
thanks guys
Modified by Its that kidfolk at 8:59 PM 6/6/2006
Old Jun 5, 2006 | 07:39 PM
an2ny888's Avatar
i have pro1's and believe me, the idle problems are no joke, sometimes i don't even want to drive the car, especially in traffic
Old Jun 5, 2006 | 08:50 PM
Default Re: Skunk2 Pro 1's or Skunk 2 Stage 2's??? (an2ny888)
thanks guys
Modified by Its that kidfolk at 9:00 PM 6/6/2006
Old Jun 6, 2006 | 09:32 AM
thanks guys
Old Jun 6, 2006 | 09:35 AM
UncleD's Avatar
Switching from S2S2's to Pro1's will give you more midrange and less top end.
Old Jun 6, 2006 | 10:13 AM
DonF's Avatar
Default Re: Skunk2 Pro 1's or Skunk 2 Stage 2's??? (clean rice)
Switching from stg2 to Pro 1's will increase the mid range and be about the same on top. Atleast on my dyno, the pro1's make more all the way to 8000 RPM.
Old Jun 6, 2006 | 10:17 AM
Default Re: Skunk2 Pro 1's or Skunk 2 Stage 2's??? (DonF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DonF &raquo;</TD></TR><TR><TD CLASS="quote">Switching from stg2 to Pro 1's will increase the mid range and be about the same on top. Atleast on my dyno, the pro1's make more all the way to 8000 RPM.</TD></TR></TABLE>
is there anything i can do, like port work to the head to make the pro 1's produce some power at top end? and maybe a smsp header?
Old Jun 6, 2006 | 10:29 AM
DonF's Avatar
What headers do you have now?
Modified by DonF at 5:49 PM 6/6/2006
Old Jun 6, 2006 | 10:46 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DonF &raquo;</TD></TR><TR><TD CLASS="quote">What heareds do you have now?</TD></TR></TABLE>
stock
Old Jun 6, 2006 | 11:40 AM
UncleD's Avatar
The better the air flow the more the cams will peak at correct Don? Meaning if you buy a better header, like an SMS, then his cams should peak higher.
Old Jun 6, 2006 | 11:42 AM
thanks guys
Kool Keith's Avatar
keep the stage 2's, they are great
Old Jun 6, 2006 | 11:50 AM
thanks guys
Old Jun 6, 2006 | 01:52 PM
DonF's Avatar
Stock headers and ex. will limit ANY cam you install. Same as using a a d-15 CX stock intake system on your 2.0 with cams.
Old Jun 6, 2006 | 02:45 PM
SF_EF8's Avatar
pro1's are an excellent cam.....
i'm using them on my build that'll be done in a month or so.
Hope to get the 200 mark for sure.
Old Jun 6, 2006 | 05:55 PM
MR_Ek4's Avatar
Default Re: (Kool Keith)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kool Keith &raquo;</TD></TR><TR><TD CLASS="quote">keep the stage 2's, they are great</TD></TR></TABLE>
no point in buying a whole new cam, more head work,header,IM, would most likely be the best decision for power in your situation.
Old Jun 6, 2006 | 06:06 PM
Default Re: (EM1_00MRBuilt)
thanks guys
Old Jun 6, 2006 | 07:05 PM
itgsr98's Avatar
what are you using to tuning with. some time on the dyno with a good tuner will get there, but you will need to do the things already suggested first. GL
Old Jun 6, 2006 | 08:15 PM
Natural Aspirations's Avatar
Why the hell did you ruin your own post by erasing all of your comments?
Old Jun 6, 2006 | 08:22 PM
Default Re: (crixzc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crixzc &raquo;</TD></TR><TR><TD CLASS="quote">Why the hell did you ruin your own post by erasing all of your comments?</TD></TR></TABLE>
umm because i wanted too since it came to a conclusion and end already if you read the top post
Old Jun 8, 2006 | 11:12 PM
Supahr_Ed's Avatar
Default Re: (Its that kidfolk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Its that kidfolk &raquo;</TD></TR><TR><TD CLASS="quote">
umm because i wanted too since it came to a conclusion and end already if you read the top post </TD></TR></TABLE>
well, i believe crixzc want to say that the erased messages ruins the thread that may help another reader in the future. Thats what the archieve is for, past information that may/may not be solved but should in the end, help someone else with their situation.
Old Jun 9, 2006 | 03:05 AM
Default Re: (Supahr_Ed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Supahr_Ed &raquo;</TD></TR><TR><TD CLASS="quote">well, i believe crixzc want to say that the erased messages ruins the thread that may help another reader in the future. Thats what the archieve is for, past information that may/may not be solved but should in the end, help someone else with their situation.</TD></TR></TABLE>
Exactly
SoyMilk
Apr 26, 2007 01:10 PM
b18_EM1
Jul 22, 2006 03:55 PM
Nov!ce
Jan 3, 2005 09:08 AM
Unsung
May 13, 2003 05:56 PM
hYpE-R-29
Jul 5, 2002 05:35 PM
