More tranny probs - popping out of 2nd gear
Old Jun 5, 2006 | 04:08 PM
TurboGoKart's Avatar
Default More tranny probs - popping out of 2nd gear
Ok, so I picked up a Y8 tranny with a bad ISB. With the help of a friend who has fixed this before we changed out the input shaft bearing and seal, and the 2 washers. Put the tranny back together, and put it back in the car. I know this was stupid, and I am going to change it tomorrow, but all I had at the time was gear oil. So I put that in the tranny. I am going to get some Honda MTF or Synchromesh and use that.
With all that said, it keeps popping out of 2nd gear. It only does it in 2nd gear, and seems like it does it more when I go around a left turn. The only possible causes of this that I know are tranny fluid and bad 2nd gear synchro.
Does anyone have any other ideas, or could something possibly be aligned wrong? Clutch slave cylinder hooked up bad? Something with the shift rod that goes to the tranny? I'm kinda lost, and I dont want to pull the tranny again unless I have to. Obviously we took the mainshaft/countershaft assembly out of the tranny when we did the ISB replacement. I am 99% sure we hooked it up just like we took it apart. What could we have misaligned if it was something inside?
Old Jun 5, 2006 | 04:14 PM
b16_DIM's Avatar
Default Re: More tranny probs - popping out of 2nd gear (TurboGoKart)
Id put money on the fluid, I had a prob with a y80 popping out of 5th. Turns out it was leaking oil and I ended up burning the gears before i got more in expensive mistake...
Old Jun 5, 2006 | 04:17 PM
I guess I just dont understand how just changing the fluid will make it not pop out of one gear. You would think if it was the fluid, it would pop out of more gears.
Old Jun 5, 2006 | 06:42 PM
Honda Bull's Avatar
Default Re: (TurboGoKart)
The motor oil is fine.... just not for everyday driving really. But it's not gonna hurt anything temporarily. Definately get some Honda MTF or any transmission fluid. But the fluid isn't going to be the problem.
Either it had more wrong than just the ISB or you put it back together wrong. Did you put the two washers in the correct way?
Old Jun 5, 2006 | 06:48 PM
Default Re: (Honda Bull)
The oil isnt really motor oil...it's more like 75W-80 or 90.
The 2 washers are in the right way. I was more talking about the fact that we had the whole mainshaft/countershaft assembly out. There was a thread on here in this section that pointed to a really nice write up of how to change synchros and what not, but the pictures are down, so that's not much help.
Old Jun 6, 2006 | 04:04 AM
Honda Bull's Avatar
If you didn't pull the actual main shaft or counter shaft apart (and just lifted them out) then it's somewhat hard to run into problems. So as long as the washers were put in properly, then the 2nd gear synchro could just be f00ked.
Old Jun 6, 2006 | 05:46 AM
Sweet.
Would it make a difference if it only did it at low rpms? Once I get higher, it doesnt pop out.
Old Jun 6, 2006 | 07:06 AM
Honda Bull's Avatar
Usually you'll find out that when you release load from the engine/drivetrain (let off the throttle) you'll find out that the gear will fall out of gear with the synchro bad. With load on it, mostly it won't fall out.
Old Jun 6, 2006 | 06:21 PM
Blown90hatcH's Avatar
How is the countershaft upper bearing? Are you sure you bought/installed the correct mainshaft bearing.
Old Jun 6, 2006 | 09:34 PM
Default Re: More tranny probs - popping out of 2nd gear (Blown90hatcH)
Not sure about the countershaft bearing, but I did order the right stuff. Got it from hondapartsdeals.com.
Old Jun 6, 2006 | 10:34 PM
Bense's Avatar
[QUOTE=TurboGoKart]The oil isnt really motor oil...it's more like 75W-80 or 90. QUOTE]
please tell me that you're not running 75W-80 in your transmission.
that's a thick weight oil used for much larger transmissions
10w-30 non-synthetic oil if you're going to use motor oil.
honda mtf of gm synchromesh.
if it's red, purple, green, blue, whatever, don't put it in the tranny.
Old Jun 7, 2006 | 04:34 AM
Honda Bull's Avatar
Default Re: (Bense)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bense &raquo;</TD></TR><TR><TD CLASS="quote">if it's red, purple, green, blue, whatever, don't put it in the tranny.</TD></TR></TABLE>
wittynamessuck
Honda Civic (2001 - 2005)
Aug 1, 2011 10:33 AM
jordan_rael_420
Oct 18, 2010 04:57 PM
MrExclusive
Feb 4, 2010 07:52 AM
frontwheelfanatic
Nov 29, 2006 06:07 PM
Fr0m4311
Apr 7, 2002 09:31 PM
