Droping a H22a into a 91 integ show car
Ok to start it off my 91 integ RS is a show car = subs, amps, etc heavy ******... im wondering what if i drop a h22a what would i need to get it to a 11 or 12 seconds 1/4 a mile... turbo , built etc w/e... will it work ? wat should i put in it n so on? or should i drop something else? im looking for a setup that is relyable at the same time so yea... the cars weight is probably 200-300pounds heavier than the stock integ
2-300 lbs isnt that much, its like driving your car with 2 people yeah? Putting in a gsr/type r with a blingy turbo kit would be cool but since you said its a show car, turbo h22? turbo k20? turbo k24vtec!?
Yes the h22 will be quicker then the b18 but its got a lot more torque which will help with the weight when your just cruising. IMO anything built or even midly built will be enough to handle a couple extra 100 lbs
im looking for a setup that will get a my integ thats about 2700 pounds to 11 secs or 12 o.O im looking at the h22a atm which seems to be a good bet? anyone disagree or agree? n wat should i do with it / with the tune internals wat to get etc
If i was making a show car i wouldnt dump money into a freakin non vtec motor personally, id have something nicer such as a gsr or type r and build off of that.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by delLudeVTEC »</TD></TR><TR><TD CLASS="quote">If i was making a show car i wouldnt dump money into a freakin non vtec motor personally, id have something nicer such as a gsr or type r and build off of that.</TD></TR></TABLE>
Get out of here you vtec loving douchebag. He can make more than enough power with a turbo without VT@kkkk!
And since when did vtec become only for showcars. GTFO
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lVlemphizStylez »</TD></TR><TR><TD CLASS="quote">you think youre gonna drop in an h22 and run 11's?</TD></TR></TABLE>
Not drop one in but you can do and H2B this has been covered a million times. There is a mount kit for the DA. Reseach is your friend. I have an H22 in my DC, put one in your DA and for less than 3k you can have a low 12 second or high 11 second car all motor easy.
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Xyphon »</TD></TR><TR><TD CLASS="quote">Is h22a even worth it? or should i build a engine straight up from scratch for 400hp + no nos</TD></TR></TABLE>
yes, this is what you should do.
3K into a nice turbo setup on your motor (built of course)
instead of asking for links, do some resarch.
If this really is a show car, you should install a K-series motor and turbo that. Make the valve cover and **** all blingety bling with crome.
Real show car, like goes no where? Do a custom K20 swap w/ turbo.
Somewhat driver? Get an Explicit Performance mount kit, put an H22 in.
Want cheaper H22 w/ your existing tranny? H2B kit, throw the rest of the swap money into a good valvetrain.
11's would be possible with a GOOD launch, slicks, and a bottle. 12's w/o the bottle on a real good launch.
Post pics of your car if it is the blingety
