brakes
have a 91 crx came stock with rear disc brakes and i did the integra swap in the front with brembo cross/drilled in the front and rear with axxis pads with the brake booster with mc and pro prot valve every since i ahve done it the e-brake does not lock up any more and i bleed the whole system any one got any suggestions
punctuation please.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91cleancrxsi »</TD></TR><TR><TD CLASS="quote">have a 91 crx came stock with rear disc brakes and i did the integra swap in the front with brembo cross/drilled in the front and rear with axxis pads with the brake booster with mc and pro prot valve every since i ahve done it the e-brake does not lock up any more and i bleed the whole system any one got any suggestions</TD></TR></TABLE>
Have you gotten under the console and tightened down on the ebrake adjustment bolt? It's like a bracket that attaches to both cables and if you tighten it, it will take less handle travel to lock the rear brakes up.
89dxhunchback
37
Jan 1, 2005 12:07 PM
