Idle problem
Old Jun 5, 2006 | 02:19 PM
egmadness's Avatar
Default Idle problem PLEASE HELP!!!
I just did a gsr swap in to my coupe and the idle is high for sum reason. It is idleing at 1500 when we have set the ecu for 700. I have done all the basic check like checking the vacum lines and the lookin for any leakes but nothing. The only thing I found is the line from the break booster is not getting persure at all. Not sue if is the booster or the lines. Couldn't find any holes on the line. Does anyone have any ideas.
Modified by egmadness at 6:34 PM 6/5/2006
Old Jun 5, 2006 | 02:21 PM
JDM-97CX's Avatar
Default Re: Idle problem PLEASE HELP!!! (egmadness)
Do you mean the vacuum line to the booster from the intake manifold?
Old Jun 5, 2006 | 02:26 PM
egmadness's Avatar
Yea that line that comes up and out to the booster.
Old Jun 5, 2006 | 02:28 PM
JDM-97CX's Avatar
Default Re: (egmadness)
When you pull the line off on the BOOSTER side it has no vacuum at all at idle?
Old Jun 5, 2006 | 02:35 PM
egmadness's Avatar
none at all. It the idle does not go up or down just stays at 1500
Old Jun 5, 2006 | 02:48 PM
JDM-97CX's Avatar
Pull the line completey off to see if it is clogged. Because the only reason why there would be no vacuum in the line is a clog in the line.
Old Jun 6, 2006 | 08:16 AM
egmadness's Avatar
the line is not cloged
Old Jun 6, 2006 | 08:33 AM
JDM-97CX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egmadness &raquo;</TD></TR><TR><TD CLASS="quote">the line is not cloged
Well then you need to figure out why your engine is not pulling any vacuum.
Old Jun 7, 2006 | 09:18 AM
egmadness's Avatar
I changed the booster wit a gsr, it stayed about the same.
Old Jun 7, 2006 | 09:34 AM
Slamaccord's Avatar
make sure the vaccum fitting on the manifold isn't bent or crushed.
jayscivi
13
Dec 30, 2011 04:27 PM
adamjenkins80
Apr 15, 2005 09:04 AM
jackstands
Dec 14, 2004 05:32 PM
HYBRIDHATCH92
Apr 1, 2002 10:41 PM
