ITR LSD?
Old Apr 15, 2002 | 09:32 AM
cr00klyn718's Avatar
Default ITR LSD?
how much should a use ITR Lsd should with 15k miles on it go for?...i found one for 400. also would the ITR LSD fit a b16a3 engine? thanks
Old Apr 16, 2002 | 12:37 PM
Rocket's Avatar
Default Re: ITR LSD? (cr00klyn718)
That sounds like a good price. Make sure it is clean and that **** doesn't get into the gears.
It'll will fit into your tranny fine. You'll probably want to use the 80mm cartridge bearing setup instead of the tapered roller bearings it has on it now.
Old Apr 16, 2002 | 02:57 PM
Default Re: ITR LSD? (Rocket)
thanks....ne reason why i should use a 80mm bearing instead of the tapered bearings?
Old Apr 28, 2002 | 03:38 AM
Rocket's Avatar
That depends on the skills and patience of the installer. Installing the diff with the cartridge bearings is easier.
samuraijackass
Transmission & Drivetrain
22
Feb 21, 2011 09:15 PM
powerneedy
Mar 21, 2008 05:39 AM
pdiggitydogg
Jul 15, 2006 03:05 PM
importboi22
Jul 23, 2004 03:24 PM
