shimming itr lsd
Old Jul 14, 2006 | 08:19 AM
pdiggitydogg's Avatar
Default shimming itr lsd
I need to measure and shim my itr lsd (Im using the newer bearings)...
But, for whatever reason, I cannot get the housings together, when the main and countershafts are in place. Other people can...but apparently, I am inept
Since I need to pay someone to put them together, I only want to have it done once, and this is job that needs to be done twice...SO:
I was wondering if I could get away with measuring for shims, with the 2 shafts out of the tranny?
Then, once its all measured and properly shimmed, I can install the shafts.
I dont see it being a problem...but I figured I should ask for thoughts, first.
Modified by pdiggitydogg at 12:40 PM 7/14/2006
Old Jul 15, 2006 | 05:57 AM
tttttttttttttttttt
Old Jul 15, 2006 | 10:30 AM
come on...
Old Jul 15, 2006 | 02:57 PM
IN VTEC's Avatar
Default Re: shimming itr lsd (pdiggitydogg)
I always shim the diff with the counter and main shafts removed. That way, I don't have to fiddle with getting the casing perfectly aligned over five or six things instead of just two.
If you're shimming the mainshaft, then you can do it with the diff out.
Old Jul 15, 2006 | 03:05 PM
perfect!
thank you!!
boosted91crx
Transmission & Drivetrain
10
Jun 29, 2009 07:09 AM
BoostedGSRBubble
Oct 15, 2002 11:04 AM
RedTeg95
Mar 20, 2002 06:30 AM
meanteg
Dec 9, 2001 02:41 PM
