jdm p30 ecu automatic? can i convert it?
Old Jun 5, 2006 | 10:58 AM
hybridpatient95's Avatar
Default jdm p30 ecu automatic? can i convert it?
i have a jdm p30 ecu and its automatic.. i was wondering if i can convert it to manual.. this board looks a hole lot different then the usdm boards.. i cant seem to locate the pins that i need to change..
any one have a problem like this?
Old Jun 5, 2006 | 10:59 AM
sicones's Avatar
Default Re: jdm p30 ecu automatic? can i convert it? (hybridpatient95)
someone asked about this same thing last week, sell the ecu for a manual one before you end up ******* it up
Old Jun 5, 2006 | 11:11 AM
Default Re: jdm p30 ecu automatic? can i convert it? (sicones)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sicones &raquo;</TD></TR><TR><TD CLASS="quote">someone asked about this same thing last week, sell the ecu for a manual one before you end up ******* it up </TD></TR></TABLE>
word good point.. cause this makes my engine surge, but when i put a 5 speed ecu in idles like a new born lol
Old Jun 5, 2006 | 11:16 AM
nolimitlowrider's Avatar
Hey I was told phearable.net will chip and convert the auto to 5 speed for 100.00 I am going to get mine jdm p30 chipped here soon. Hope this helps. Mike
Old Jun 5, 2006 | 03:08 PM
Relic1's Avatar
how-to... http://www.pgmfi.org/twiki/bin...anual
It's not difficult, 10 minutes if you can solder really well. No chipping required.
Old Jun 5, 2006 | 06:52 PM
yea i found that before i left for work... thanks alot guys im going to buy the 1.4k ohm resistor tomorrow
Old Jun 6, 2006 | 10:17 AM
anyone know how many watts these resistors have to have?
Old Jun 6, 2006 | 10:56 AM
Relic1's Avatar
the smaller the better for ease of install, keep in mind that OEM uses surface mount, which is far less than the crap you buy from radioshack.
Old Jun 6, 2006 | 11:57 AM
what im talking about is how much watts does this 1.4k resistor have to have.. to went to look at some resistors and i wasnt sure which one some have the 1/2 watts some have 1 watts and on
Old Jun 6, 2006 | 12:04 PM
Relic1's Avatar
the smaller the wattage the smaller the case of the resistor, the smaller the case the easier it is to mount to the surface mount location of the JDM P30.
keep in mind that the stock ECU uses parts that are maybe 1/16 watt at best.
easy answer.... the standard 1/4 watt 1.4k ohm resistor works fine. anything larger makes it a pain to get it in the case of the ECU without touching anything else.
Old Jun 6, 2006 | 12:25 PM
ooh ok thanks for your info ... since radio shack didnt have a 1.4k resistor ima go hunting for one in my broke p28 lol
spike
Aug 22, 2004 08:34 AM
hypa
Mar 26, 2004 09:58 PM
hypa
Dec 28, 2003 06:45 PM
LBR92DA-T
Dec 7, 2003 06:30 PM
-16V-
Feb 17, 2003 10:38 AM
