Which spark plugs?
Old Jun 5, 2006 | 10:53 AM
Kovatch EG's Avatar
Default Which spark plugs?
I went to go buy spark plugs the other day and realized i probably couldnt just get some plugs for a b16a.
I'm running a b16 head/bottom end with CTR pistons, my question is: Which would be the best plugs to use for my setup...
Old Jun 5, 2006 | 11:04 AM
broketuner-Sol_Si's Avatar
Default Re: Which spark plugs? (Kovatch EG)
I've used densos or NGK iridiums in all of my setups....never a problem yet, but then again I've never used CTR pistons, and they've all been near stock CR
Old Jun 5, 2006 | 11:10 AM
92TypeR's Avatar
FSAE
Default Re: Which spark plugs? (broketuner-egb16a)
NGK Copper BKR7E-11. Cheap, reliable, perform well.
Old Jun 5, 2006 | 11:32 AM
Kovatch EG's Avatar
but will that clear my pistons?
Old Jun 5, 2006 | 11:39 AM
black_EM1's Avatar
Community Builder
Community Influencer
Default Re: (Kovatch EG)
They should. I run the BKR6E-11 plugs in my car. You running a bit higher c/r than I am, however.
mar778c's Avatar
Community Builder
Default Re: Which spark plugs? (92TypeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92TypeR &raquo;</TD></TR><TR><TD CLASS="quote">NGK Copper BKR7E-11. Cheap, reliable, perform well.</TD></TR></TABLE>
Agreed.
Old Jun 5, 2006 | 12:28 PM
Nick M's Avatar
Default Re: Which spark plugs? (mar778c)
i picked up 1whp and 3ft/lbs with Rocket's modified plugs
Old Jun 5, 2006 | 06:09 PM
PURPLETERROR aka BIGMATT's Avatar
Default Re: Which spark plugs? (Nick M)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nick M &raquo;</TD></TR><TR><TD CLASS="quote">i picked up 1whp and 3ft/lbs with Rocket's modified plugs</TD></TR></TABLE>
ROckets plugs are good ****, I run the bkr7e11's and do a little "rocket" modification of my own to them
Old Jun 6, 2006 | 03:15 AM
Kovatch EG's Avatar
what exactly is the modification he does?
still need to know what plug to use with my CTR pistons???
Old Jun 6, 2006 | 04:24 AM
Nick M's Avatar
have you not read any of the posts in this thread?
Old Jun 6, 2006 | 09:06 AM
SkoundrelUSA's Avatar
cute little bastard
Where did you get them? Gotta PM Rocket directly?
Old Jun 6, 2006 | 09:07 AM
Nick M's Avatar
Default Re: Which spark plugs? (SkoundrelUSA)
if i remember right I got them from Kteller, he sells them i think
Old Jun 6, 2006 | 11:50 AM
black_EM1's Avatar
Community Builder
NGK Copper BKR7E-11
Old Jun 6, 2006 | 01:12 PM
Kovatch EG's Avatar
so i can use the same plugs as stock b16 even tho im running domed pistons?
peacexisxfree
Oct 31, 2005 07:13 AM
Iomega01
Oct 16, 2005 09:43 PM
Phatch99
Sep 8, 2005 12:39 PM
Si Erik
26
Jan 10, 2004 11:05 AM
rice a roni
27
Dec 7, 2003 01:08 PM
