checked cel, pulled jumper, now no start
Old Jun 5, 2006 | 10:42 AM
Dave421's Avatar
Default checked cel, pulled jumper, now no start
Did some maintenance on my sol today and was trying to replace some sensors that I thought were bad (apparently a wiring issue). After I replaced them, I reset the ecu and checked the codes. I never pulled the jumper out after checking them. Later, I was driving down the road when I noticed the cel still flashing so I pulled the jumper out. The car just died. Now, it won't start. It didn't seem to be getting any spark. Couldn't find any blown fluses, cel is still flashing code 10 (so I'd assume the ecu is ok), and no obvious problems. Car is a 95 sol w/ a jdm b16 and hondata on a p28. Tried resetting the ecu and that had no effect. Anybody run into this before? Tried searching but couldn't find anything.
Old Jun 5, 2006 | 10:51 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: checked cel, pulled jumper, now no start (Dave421)
I probably wouldn't have pulled the jumper while you were driving it. When the car is running, that jumper prevents the ignition timing from automatically adjusting.
Hope you resolve the problem.
Old Jun 6, 2006 | 09:26 AM
Dave421's Avatar
good to go again. replaced the icm and coil and she's running. thanks for the help
em2crusin
K Series
Jun 9, 2013 11:40 PM
jtjtjt
22
Feb 17, 2012 02:46 PM
tec_wiz
Jun 5, 2006 09:01 AM
liquidxEG
Feb 22, 2005 03:46 PM
