Master clutch cylinder??
Old Jun 4, 2006 | 10:02 PM
92eg6lsvtec's Avatar
Default Master clutch cylinder??
oki bought a teg. the clutch is loose. it only pops 1/3 of the way up. just enough to engage the clutch. i bled the clutch and nohting helped. I just swapped out the slave cylinder since a friend had an extra one. And its exactly the same, but when blleding the clutch, when the bleeder is open it doesnt squirt hard, just a little bit. On all my other hondas when opening the bleeder valve to bleed it they usually squirt hard. There are no signs of leaks anywhere, nothing even around the MCC. Could it be the MCC even with no leaks...
Old Jun 4, 2006 | 11:05 PM
Default Re: Master clutch cylinder?? (92eg6lsvtec)
bump for me needing any kind of help asap!
Old Jun 4, 2006 | 11:08 PM
__oversea's Avatar
could be pressure plate then..mine leaks.haha
Old Jun 5, 2006 | 12:20 AM
Toofresh559's Avatar
I've had that problem before and I thought it was my clutch that was running out but it was the Clutch Master Cylinder so I replaced it with a new one and that was it!! hope that helps.
Old Jun 5, 2006 | 05:28 AM
Default Re: Master clutch cylinder?? (Toofresh559)
thnx any others before i go buy one?
Old Jun 5, 2006 | 08:43 AM
hondafan62269's Avatar
I too had the same problem. Check under the dash and take a look at the back of the master. Mine was leaking there.
ohsnapzafingcu
May 16, 2011 04:30 PM
zach1288
Jan 21, 2010 03:16 PM
integra3586
Oct 30, 2005 09:20 PM
s1ngle
13
Sep 21, 2005 12:01 PM
teglsturbo
Apr 27, 2004 04:16 PM
