checked cel, now car won't start
Old Jun 4, 2006 | 08:54 PM
tec_wiz's Avatar
Default checked cel, now car won't start
Did some maintenance on my sol today and was trying to replace some sensors that I thought were bad (apparently a wiring issue). After I replaced them, I reset the ecu and checked the codes. I never pulled the jumper out after checking them. Later, I was driving down the road when I noticed the cel still flashing so I pulled the jumper out. The car just died. Now, it won't start. It didn't seem to be getting any spark. Couldn't find any blown fluses, cel is still flashing code 10 (so I'd assume the ecu is ok), and no obvious problems. Car is a 95 sol w/ a jdm b16 and hondata on a p28. Tried resetting the ecu and that had no effect. Anybody run into this before? Tried searching but couldn't find anything.
Old Jun 5, 2006 | 12:03 AM
Dave421's Avatar
*bump* need help with this. nobody knows???
Old Jun 5, 2006 | 12:14 AM
trevor72's Avatar
Default Re: (Dave421)
you pulled the jumper while driving?
what happened when you pulled the key out and tryed again from scratch without the jumper? Nothin' ?
Sorry, I don't know alot about honda's myself hopefully someone else will chim in.
Trevor
Old Jun 5, 2006 | 09:01 AM
tec_wiz's Avatar
bump
em2crusin
K Series
Jun 9, 2013 11:40 PM
jtjtjt
22
Feb 17, 2012 02:46 PM
Dave421
Jun 6, 2006 09:26 AM
95LSS
Mar 7, 2004 11:00 AM
