will 90-93 integra brakes fit on a 92-95 civic?
Old Jun 4, 2006 | 08:50 PM
See Are X's Avatar
Default will 90-93 integra brakes fit on a 92-95 civic?
will the 90-93 teg brakes(front and rear) fit directly onto a 92 civic?
Old Jun 4, 2006 | 08:54 PM
JDM-EJ1's Avatar
Default Re: will 90-93 integra brakes fit on a 92-95 civic? (See Are X)
No.
Old Jun 4, 2006 | 10:01 PM
dem0nk1d's Avatar
Default YES YES!!!! The rear's will work like a champ!
The rear will fit just fine. I did the swap on my Civic Hatchback DX. I used 90-93 rear teg trailing arms with the disc setup. Everything bolt up fine. I used the stock civic's lower control arm and the toe arm. So all you need is the integras complete trailing arm with breaks. And your set. Also don't for get to use the integra brake lines...
So yes YES yes!!!! For the rear...
Old Jun 5, 2006 | 01:26 AM
BlueIntegraBoy's Avatar
The front won't and will have crazy toe if you do use them.
Old Jun 5, 2006 | 05:41 AM
T-RO's Avatar
there is a How to on here that shows you that you can just unbolt the rear hub and use your Civic trailing arm. Then use 00 SI e-brake cables
Old Jun 5, 2006 | 06:12 AM
PhatBoy5015's Avatar
Default Re: (T-RO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by T-RO &raquo;</TD></TR><TR><TD CLASS="quote">there is a How to on here that shows you that you can just unbolt the rear hub and use your Civic trailing arm. Then use 00 SI e-brake cables</TD></TR></TABLE>
I have a 97 coupe and I used the entire rear setup from a 92 Integra. Even the e-brake cables worked perfectly. And if you check the part numbers on the proportioning valve between 96-00 Civics with rear drums and 99-00 Si's, they are the same.
Old Jun 5, 2006 | 07:16 AM
pdiggitydogg's Avatar
the valve # is only the same for hatches
and yeah, rears fit fine
twotonecivic
Jan 18, 2007 06:54 PM
ED3_FTW
Dec 16, 2006 04:32 PM
dem0nk1d
Mar 16, 2006 11:45 AM
vtecb20coupe
Jul 8, 2004 12:26 PM
92hybridhhatch
Feb 7, 2003 09:46 AM
