Fuel management for turbo
Old Jun 4, 2006 | 07:13 PM
WalkerGSR1's Avatar
Default Fuel management for turbo
I wanted to know if a v-afc 2 is good to for 7 psi tune on a 00 gsr?
Old Jun 4, 2006 | 07:14 PM
.brian.'s Avatar
Default Re: Fuel management for turbo (WalkerGSR1)
edited:
https://honda-tech.com/zerothread?id=137901
but i would look into
hondata
uberdata
crome
Old Jun 4, 2006 | 07:20 PM
WalkerGSR1's Avatar
i asked becuz i seen people tune their turbo cars with v-afc2 and have no problems. I am obd2 and done feel like converting to obd1
Old Jun 4, 2006 | 07:48 PM
AViciousTHRUST's Avatar
Default Re: (WalkerGSR1)
and obd2 to obd2 conversion harness only cost about 75 bucks
Old Jun 4, 2006 | 07:53 PM
TurboGS-R's Avatar
Default Re: (AViciousTHRUST)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AViciousTHRUST &raquo;</TD></TR><TR><TD CLASS="quote">and obd2 to obd2 conversion harness only cost about 75 bucks</TD></TR></TABLE>
I think you mean OBD2 to OBD1. You should get Hondata or AEM EMS because after tuning, your car will see more of it's potential than just using VAFC.
Old Jun 7, 2006 | 03:27 AM
WalkerGSR1's Avatar
why does the Aem ems cost so much more than the hondata? is it worth buying the EMS for 1500?
Old Jun 7, 2006 | 08:01 AM
Pnoyej6's Avatar
* B A N N E D *
Crome Pro
Im tuned with Crome on 7ilbs daily driver and it runs like a champ. Im obd 2 too and converted to obd1. easy as a conversion harness and Obd 1 p28 chipped ecu.
Old Jun 7, 2006 | 11:30 AM
WalkerGSR1's Avatar
why do you guys use the p28 ecu? does it control the butterflies like the p72?
Old Jun 7, 2006 | 11:40 AM
Pnoyej6's Avatar
* B A N N E D *
im running a skunk 2 intake manifold on my 00 gsr with obd1 p28 chipped ecu. no cel no need to worry about the secondaries on the stock gsr manifold
Old Jun 7, 2006 | 11:44 AM
WalkerGSR1's Avatar
ight thanks. when you put in your skunk 2 manifold how much of a power difference did it make?
Old Jun 7, 2006 | 12:53 PM
Pnoyej6's Avatar
* B A N N E D *
i felt the difference at top end. big difference. pull s harder especially at full boost
Old Jun 7, 2006 | 05:18 PM
JmurGSR98's Avatar
what other options do you have if you don't want to do a obd-2 to obd-1 conversion without having to pay $1500 for an AEM-ems?
Old Jun 7, 2006 | 07:51 PM
1turbodc2's Avatar
nothing that is it, and also u can't use a VAFC, with an obd2b ecu, cause one u will not have enough adjustablity, 2 obd2 willl learn around the setting u set, either go ems, or go crome pro, i am personally using crome pro, and it runs perfect and i run 10 psi daily( not that psi mean ****) but still stop tryin to be cheap about the one thing that u should have the best of engine management...
want a car that will last good engine management, good fueling, good tune do it right or don't do it at all!
Old Jun 7, 2006 | 08:29 PM
Pnoyej6's Avatar
* B A N N E D *
Default Re: (1turbodc2)
bump do it right the first time Crome Pro Cheap and reliable
Old Jun 7, 2006 | 08:49 PM
94lsvtec's Avatar
has anybody tuned with smc500??
Old Jun 7, 2006 | 08:51 PM
SoEvoL's Avatar
Default Re: (94lsvtec)
hondata, chrome, neptune
cant go wrong there
Old Jun 8, 2006 | 02:45 AM
WalkerGSR1's Avatar
for crome pro, do i have to convert to obd 1? and how much does it cost?
Old Jun 8, 2006 | 09:22 AM
Pnoyej6's Avatar
* B A N N E D *
yes you have to convert to obd1. harness obd2b-obd1 harness cost 80 bucks and the obd1 p28/ecu chipped cost about 150
Old Jun 8, 2006 | 12:06 PM
00IntegrAllmotoR's Avatar
HT Black OPs
Default Re: (pnoytegn707)
Dont forget the injector clips
lsnidex
Engine Management and Tuning
Jan 14, 2009 08:02 AM
eggie75
Aug 8, 2008 11:28 AM
juevi (old)
Jan 26, 2007 10:33 PM
KseriesSLUG
Jan 16, 2005 03:19 PM
yeegsr
Oct 19, 2004 10:10 PM
