Coupe wont start???
my ej is trying to turn over...but wont, and i kno its not the battery...please help
just got my oil changed could they have messed somethin up???(i kno it sounds weird but never had this problem)
We need a little more info. How fast is it spinning over? It may be a bad connection or the starter. Also check the main relay if it spinning over fast but not starting. It could be a spark or fuel problem
It could be several things. But first you need to check for spark. Pull out a plug and put the plug back in the wire, place the plug near the block (ground), have someone start it and see if it is sparking. If it is it might be the plugs are fouled out. Still not enough info.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jb55 »</TD></TR><TR><TD CLASS="quote">no cel....i dunno what to post all i know is it wont spin over, like i said its spinning fast...i think its the plugs does that sound right???</TD></TR></TABLE>
Your confusing me. Does the motor turn over or no?
Have you checked for fuel and spark?
fwdftw
52
Sep 5, 2006 11:31 PM
