crazy ass spark plug problem, weird!!
Old Jun 4, 2006 | 12:43 PM
B16CivicEX's Avatar
Default crazy *** spark plug problem, weird!!
hey guys i bought a 2000 ex a while back with a swap all ready done, its a b16, i was doing rutine maintence and wanted to change plugs. i went to autozone and got the plugs for a 2000 civic SI with the b16A2, (my engine says b16A on it ) installed the plugs for a VTECH DOHC B16A2, and the car spits and spudders and wont excellerate.. thought it was weired, took the old plugs that i had pulled out in to napa, and they did a search on them and told me they go in a 2001 integra type-r and not a b16. i asked for a set of those plugs for a 2001 integra type-r and installed them and the car runs fine? why would the car spit and spudder on a plug for a 2000 si with a b16? from why i know about my car its a stock b16A2. Thanks for the help.
Old Jun 4, 2006 | 12:48 PM
sol2hatch's Avatar
Default Re: crazy *** spark plug problem, weird!! (AirForceB16)
how sure are you that it is a stock b16? are b16 and b18 plugs different? sounds like it. possibly a b18 head on a b16 block???
Old Jun 4, 2006 | 12:51 PM
Archidictus's Avatar
Unceasing Measure
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AirForceB16 &raquo;</TD></TR><TR><TD CLASS="quote">hey guys i bought a 2000 ex a while back with a swap all ready done, its a b16, i was doing rutine maintence and wanted to change plugs. i went to autozone and got the plugs for a 2000 civic SI with the b16A2, (my engine says b16A on it ) installed the plugs for a VTECH DOHC B16A2, and the car spits and spudders and wont excellerate.. thought it was weired, took the old plugs that i had pulled out in to napa, and they did a search on them and told me they go in a 2001 integra type-r and not a b16. i asked for a set of those plugs for a 2001 integra type-r and installed them and the car runs fine? why would the car spit and spudder on a plug for a 2000 si with a b16? from why i know about my car its a stock b16A2. Thanks for the help.</TD></TR></TABLE>
There's your problem right there. Spark plugs for a phone won't work in a car, you silly ****.
B16CivicEX's Avatar
all i know is the bottom end is stamped b16A all i see on the haed is PR3-4? how can i tell if i have a b18 head.. what car is a b18 off of, integra?
Old Jun 4, 2006 | 12:56 PM
CardDealer's Avatar
Banned
Modified by CardDealer at 10:00 AM 11/16/2006
Old Jun 4, 2006 | 12:57 PM
B16CivicEX's Avatar
the old plug i took out was a NGK BKR7ES-11
Old Jun 4, 2006 | 01:00 PM
byronl's Avatar
autozone doesn't carry NGK's, i asked them if they did but the guy at the clerk said he didn't, i have to go to some other place to get them.
B16CivicEX's Avatar
i was a advance auto parts. they have NGK
Old Jun 4, 2006 | 01:01 PM
B16CivicEX's Avatar
just weired that my car would not run on a plug for a b16, but runs fine on a plug for a integra type-r
Old Jun 4, 2006 | 01:24 PM
EG93si's Avatar
Default Re: (AirForceB16)
did you gap them right or did they come pre gapped, my friend thought his came pre gapped and it did the same thing
Old Jun 4, 2006 | 01:38 PM
B16CivicEX's Avatar
i was told by the 17 year old chick that they are pre-gapped.. so i did not check. they might have not been unsure.
Old Jun 4, 2006 | 01:55 PM
JasonGhostz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AirForceB16 &raquo;</TD></TR><TR><TD CLASS="quote">i was told by the 17 year old chick that they are pre-gapped.. so i did not check. they might have not been unsure.</TD></TR></TABLE>Tell that girl she owes you, and that when she turns 18 she can repay you. One should ALWAYS check for proper gapping, even if they come "pre-gapped".
Here's NGK's application chart for the 2000 Civic SI...
http://www.ngk.com/results_app.asp?AAIA=1363025
Here's NGK's application chart for the 2001 Integra Type-R...
http://www.ngk.com/results_app.asp?AAIA=1378885
Looks like they initally sold you the wrong ones... Their application database might be at fault, but try to make the chick feel guilty and get at least a sympathy feel or something... after she turns 18...
JasonGhostz
Old Jun 4, 2006 | 02:40 PM
Brick Top's Avatar
Default Re: (JasonGhostz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JasonGhostz &raquo;</TD></TR><TR><TD CLASS="quote">Tell that girl she owes you, and that when she turns 18 she can repay you. One should ALWAYS check for proper gapping, even if they come "pre-gapped".
JasonGhostz</TD></TR></TABLE>
lol! one probably had the wrong gap
Old Jun 4, 2006 | 03:53 PM
B16CivicEX's Avatar
unsure but its running fine on integra typr-r plugs.
Old Jun 4, 2006 | 04:28 PM
sicones's Avatar
Default Re: crazy *** spark plug problem, weird!! (Archidictus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus &raquo;</TD></TR><TR><TD CLASS="quote">
There's your problem right there. Spark plugs for a phone won't work in a car, you silly ****.</TD></TR></TABLE>
LMFAO!! thats ones of the funniest things I ever read on here
b16hatch
Oct 21, 2009 07:09 PM
evsproject94
Mar 17, 2007 09:08 AM
spoonracer84eg
Mar 20, 2006 08:38 AM
ap1amor
Jun 20, 2004 05:06 PM
