Car won't run
Old Jun 4, 2006 | 09:22 AM
silvestri51's Avatar
Default Need help.......!?!?!
Two weeks ago when i pulled my e-brake to park the car just shut off and won't run anymore. We figured out it is getting no fuel and no spark. We changed the distributor, checked all fuses, changed the ecu,does anyone have any idea wha the problem could be.?
Old Jun 4, 2006 | 09:23 AM
Slamaccord's Avatar
Default Re: Need help.......!?!?! (silvestri51)
Main relay
Check your grounds
Old Jun 4, 2006 | 09:40 AM
Default Re: Need help.......!?!?! (Slamaccord)
checked all grounds and changed main relay...any other ideas?
Modified by silvestri51 at 2:23 PM 6/4/2006
Old Jun 4, 2006 | 10:40 AM
SLATER97EX's Avatar
Just curious, do you have a remote start or security system?
Old Jun 4, 2006 | 04:37 PM
Default Re: Need help.......!?!?! (SLATER97EX)
i have a security system but i disconnected that also and nothing hapend..would i have to pull more than just the fuse to disable it?
Old Jun 5, 2006 | 04:14 AM
SLATER97EX's Avatar
Does your system disable the car if tripped? Or just make alot of noise?
If it disables the car, then that could be your problem. Yes completely disabling the system if the ignition relays through it would leave you dead in the water also. What kind of security system is it?
Old Jun 5, 2006 | 06:32 PM
its a viper alarm, i pulled the fuse but that did absolutly nothing is there anything else that would disable it
Ralph3991
Honda Civic (2001 - 2005)
Oct 20, 2014 10:01 AM
Si-Samuri
Jun 13, 2009 12:50 PM
whitelotus420
Aug 1, 2008 09:05 AM
DoyouVtec
Feb 26, 2008 01:46 PM
ridin98civic
Apr 16, 2007 10:02 PM
