Want to add a turbo on a 95 accord NEED HELP
Old Jun 3, 2006 | 10:40 PM
ateeb786's Avatar
Default Want to add a turbo on a 95 accord NEED HELP
I want to add a turbo on my 95 accord, well i have a 95 engine in a 91 accord model. I havent heard anyone having a turbo in a older model accord so someone please help me out. I heard a 1g dsm turbo will work is it true?
Old Jun 4, 2006 | 01:16 PM
standbackimapro's Avatar
Default Re: Want to add a turbo on a 95 accord NEED HELP (ateeb786)
Check out this site
http://homemadeturbo.com/turbo_projects/
Theres a Few Cars on there with turboed F22's
There using DSM turbos with DSM Fuel Injectors
And actually
a friend of mine went to a junk yard, got a Side Mount intercooler from a volkswagen, had an old starion turbo, welded it straight to his stock exhaust manifold, and he ghetto rigged everything basically, but it worked, the turbo spools up and everything.. just needs to be adjusted and such..
but it is possible
He made a whole turbo kit for less than 300 dollars ( Had to buy intercooler piping, intercooler, various fittings
Old Jun 4, 2006 | 03:23 PM
ateeb786's Avatar
Default Re: Want to add a turbo on a 95 accord NEED HELP (standbackimapro)
thanks a lot this helped me out really well,
Old Jun 4, 2006 | 06:20 PM
street_accord94's Avatar
the 1g dsm manifold will not fit a 5th gen accord head (f22b1, f22b2)
Old Jun 5, 2006 | 12:04 AM
pos_cd5's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by standbackimapro &raquo;</TD></TR><TR><TD CLASS="quote">Check out this site
And actually
but it is possible
He made a whole turbo kit for less than 300 dollars ( Had to buy intercooler piping, intercooler, various fittings</TD></TR></TABLE>
what did your friend use for engine management? any power figures with this budget boost set-up?
Old Jun 5, 2006 | 05:55 AM
notoriousB's Avatar
Default Re: Want to add a turbo on a 95 accord NEED HELP (street_accord94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by street_accord94 &raquo;</TD></TR><TR><TD CLASS="quote">the 1g dsm manifold will not fit a 5th gen accord head (f22b1, f22b2)</TD></TR></TABLE>
x2!! it will only work with an F22Ax head.
Old Jun 5, 2006 | 09:39 AM
raceACCORDingly's Avatar
jdm f22b and h23 also.
Old Jun 5, 2006 | 10:19 AM
d112crzy's Avatar
learn how turbos work.
http://www.turbobygarrett.com/....html
Old Jun 5, 2006 | 09:46 PM
ateeb786's Avatar
Default Re: Want to add a turbo on a 95 accord NEED HELP (pos_cd5)
But you can redirll the holes to match it up but ill have to tune the ecu, im not sure how im planning on getting that done yet but I was wondering if i can use 2g dsm turbo and intercooler? i dont think the injectors from a 2g dsm will work because there 550cc. If not i can get 1g dsm injectors.
Old Jun 6, 2006 | 04:15 AM
he was using uberdata
Although we never had it dynoed or anything
There is a Huge noticable Difference in performance
I know that He used to loose to horribly to a volkwagen GTi
Now he keeps up
and that was before he used uberdata..
But If you think about it
When you buy a turbo from a company your buying all brand new parts, and stuff..
Go to a junkyard and your buying used stuff and your mixing and matching parts
Thats why its so cheap. If you really want to make a homemade turbo and be successful its very easy.. and you can make it perform just as well as a turbonetics kit.. or any other company
Old Jun 6, 2006 | 07:16 AM
ateeb786's Avatar
I have a 2g dsm and im goning to swap the turbo on that soon. So i was thinking about using that turbo on my accord.
Same with the intercooler but i would have to custom the pipes, it doesnt seem all that hard.
WHAT is a J-pipe??? is it the pipe where it goes on the exhast? from the turbo??
Old Jun 6, 2006 | 04:31 PM
notoriousB's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ateeb786 &raquo;</TD></TR><TR><TD CLASS="quote">But you can redirll the holes to match it up
i dont think the injectors from a 2g dsm will work because there 550cc. If not i can get 1g dsm injectors. </TD></TR></TABLE>
no you can not redrill the holes to line it up to an F22B. the ports don't line up.
2g DSM (manual trans) injectors are 450cc. what would be wrong w/ 550cc tho? I'm running 750cc injectors on my accord.
Old Jun 7, 2006 | 08:08 AM
ateeb786's Avatar
Default Re: Want to add a turbo on a 95 accord NEED HELP (notoriousB)
so how can i match up the manifold? i seen some turbo manifold for accord on ebay. Will that work fine?
Old Jun 7, 2006 | 09:03 AM
The Russian Buddha's Avatar
check this site out...http://www.turbokits.com/accord_turbo_kits.html#
and my sister has a 95 accord, the body really isn't that different then a fourth generation accord
Old Jun 7, 2006 | 10:36 AM
ateeb786's Avatar
Default Re: Want to add a turbo on a 95 accord NEED HELP (The Russian Buddha)
i have a 95 accord motor in a 91 accord model, plus im not really planning on spend a lot.
z_alchaar
Mar 9, 2016 12:50 PM
z_alchaar
Jan 16, 2016 11:37 PM
Hidenplanvew
Sep 23, 2013 08:58 PM
blackshadow113
Jan 1, 2005 09:45 PM
Polakatl
Nov 27, 2004 08:28 PM
