tightening crankshaft bolt??????
Old Jun 3, 2006 | 09:38 PM
eg6T's Avatar
Default tightening crankshaft bolt??????
what are the other ways of tightening the crankshaft bolt without using an airgun,i do not have the stock pulley so there is no key to use.
could you tighten it by putting a wrench on the bolt and cranking the motor?sounds like it would work but it also sounds like it would be bad on the crank,anyone truy this?
thanks
Old Jun 4, 2006 | 12:01 PM
eg6T's Avatar
Default Re: tightening crankshaft bolt?????? (eg6T)
anyone?
Old Jun 4, 2006 | 04:25 PM
old man neri's Avatar
I did the starter trick. So far it has yet to fall appart. Just to short burst on your starter, don't hold it down. Oh, and disconnect your injectors.
Old Jun 4, 2006 | 06:15 PM
eg6T's Avatar
Default Re: tightening crankshaft bolt?????? (old man neri)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by old man neri &raquo;</TD></TR><TR><TD CLASS="quote">I did the starter trick. So far it has yet to fall appart. Just to short burst on your starter, don't hold it down. Oh, and disconnect your injectors.</TD></TR></TABLE>
can you explain the starter trick? thanks
Old Jun 4, 2006 | 06:37 PM
You more or less explained it in your orginal post. Put a big wrench on it. Move it so it touches the ground. Then crank your starter, it will bang the wrench on the ground. The wrench won't be able to move so all the torque will be used to tighten the bolt. Just make sure disconnect your injectors.
Hope that explains it.
Old Jun 4, 2006 | 07:34 PM
eg6T's Avatar
ok cool man,you had no problems after u did this? and also do u have to disconnect the injectors or can you pull a fuse or somehting like that? thanks again
Old Jun 5, 2006 | 02:48 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6T &raquo;</TD></TR><TR><TD CLASS="quote">ok cool man,you had no problems after u did this? and also do u have to disconnect the injectors or can you pull a fuse or somehting like that? thanks again</TD></TR></TABLE>
I have yet to incounter any problems. As for the injectors all you have to do is makre sure you engine won't start. If it does you will be in a world of hurt. You could also pull your plug wires but carefull where they ground out.
I really don't know how good this is for the engine but I personally don't care too much.
Old Jun 5, 2006 | 08:59 PM
djtony5's Avatar
What I do is just unbolt the flywheel cover and jam a small screwdriver in there. Work like a charm everytime to remove the crank bolt or installing it back on.
Old Jun 5, 2006 | 11:50 PM
eg6T's Avatar
Default Re: (djtony5)
I really don't know how good this is for the engine but I personally don't care too much.</TD></TR></TABLE>
haha thanks alot for your input
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djtony5 &raquo;</TD></TR><TR><TD CLASS="quote">What I do is just unbolt the flywheel cover and jam a small screwdriver in there. Work like a charm everytime to remove the crank bolt or installing it back on.</TD></TR></TABLE>
cool man thanks ill give that a try as well
Jdmgirl00civic
Feb 16, 2016 04:29 PM
crxaddikt
Jun 12, 2012 10:48 PM
Scud
Nov 2, 2007 10:32 AM
slacks
10
Aug 27, 2007 02:23 PM
Elite Hatch
Nov 24, 2002 10:06 PM
