Coilover for everyday rough raods riding
Old Jun 3, 2006 | 05:00 PM
Del Sol on Steroids's Avatar
Default Coilover for everyday rough roads riding
What are the best coilovers out for rough roads. So with rough roads, I can't have the car riding on the floor.
Old Jun 3, 2006 | 05:32 PM
littlegreenb18's Avatar
Default Re: Coilover for everyday rough roads riding (Del Sol on Steroids)
if you have coil-overs you can set it to what height you want, for rough roads you should get ones with threaded shocks, not a sleeve, sometimes the sleeves break, omni looks good and I've seen em for like 650
Old Jun 3, 2006 | 07:53 PM
gstboi04's Avatar
Default Re: Coilover for everyday rough roads riding (littlegreenb18)
omni are dope. but the only bad thing is the damper isnt adjustable
Old Jun 3, 2006 | 07:56 PM
EK k kay's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by littlegreenb18 &raquo;</TD></TR><TR><TD CLASS="quote">if you have coil-overs you can set it to what height you want, for rough roads you should get ones with threaded shocks, not a sleeve, sometimes the sleeves break, omni looks good and I've seen em for like 650 </TD></TR></TABLE>
Quality sleeves like the Ground Controls don't break unless installed the wrong way.
Old Jun 3, 2006 | 08:00 PM
jonny_sin's Avatar
Default Re: Coilover for everyday rough roads riding (EK k kay)
i got ground control on my eg coupe and the ride is great. the only time it sucked was when my shocks wore out, but thayt has nothing to do with the coilovers
Old Jun 3, 2006 | 08:08 PM
NonovUrbizniz's Avatar
Loved
CT Roads are for ****... I have GC/Konis and they're GREAT... I'm not even all the way soft and it's plenty bearable on my daily driver with 215k miles and all poly bushings.
Old Jun 3, 2006 | 08:32 PM
hondata99's Avatar
I got nuespeed coilovers with bilstein shock and it rides not to hard for rough roads and not to soft when I drive the **** out of it. It rides better then stock.
riotchild
Suspension & Brakes
19
Aug 11, 2014 05:29 AM
ThaiRacer
Suspension & Brakes
Jun 28, 2007 09:22 PM
MrToasty
Suspension & Brakes
Apr 7, 2005 08:26 PM
spock_rocker
Jun 27, 2003 01:17 PM
BlueBalls
11
May 3, 2003 07:05 AM
