Coilover for everyday rough raods riding
Old 06-03-2006, 05:00 PM
Del Sol on Steroids's Avatar
Default Coilover for everyday rough roads riding
What are the best coilovers out for rough roads. So with rough roads, I can't have the car riding on the floor.
Old 06-03-2006, 05:32 PM
littlegreenb18's Avatar
Default Re: Coilover for everyday rough roads riding (Del Sol on Steroids)
if you have coil-overs you can set it to what height you want, for rough roads you should get ones with threaded shocks, not a sleeve, sometimes the sleeves break, omni looks good and I've seen em for like 650
Old 06-03-2006, 07:53 PM
gstboi04's Avatar
Default Re: Coilover for everyday rough roads riding (littlegreenb18)
omni are dope. but the only bad thing is the damper isnt adjustable
Old 06-03-2006, 07:56 PM
EK k kay's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by littlegreenb18 &raquo;</TD></TR><TR><TD CLASS="quote">if you have coil-overs you can set it to what height you want, for rough roads you should get ones with threaded shocks, not a sleeve, sometimes the sleeves break, omni looks good and I've seen em for like 650 </TD></TR></TABLE>
Quality sleeves like the Ground Controls don't break unless installed the wrong way.
Old 06-03-2006, 08:00 PM
jonny_sin's Avatar
Default Re: Coilover for everyday rough roads riding (EK k kay)
i got ground control on my eg coupe and the ride is great. the only time it sucked was when my shocks wore out, but thayt has nothing to do with the coilovers
Old 06-03-2006, 08:08 PM
NonovUrbizniz's Avatar
CT Roads are for ****... I have GC/Konis and they're GREAT... I'm not even all the way soft and it's plenty bearable on my daily driver with 215k miles and all poly bushings.
Old 06-03-2006, 08:32 PM
hondata99's Avatar
I got nuespeed coilovers with bilstein shock and it rides not to hard for rough roads and not to soft when I drive the **** out of it. It rides better then stock.
riotchild
Suspension & Brakes
19
08-11-2014 05:29 AM
ThaiRacer
Suspension & Brakes
06-28-2007 09:22 PM
MrToasty
Suspension & Brakes
04-07-2005 08:26 PM
spock_rocker
06-27-2003 01:17 PM
BlueBalls
11
05-03-2003 07:05 AM
Quick Reply: Coilover for everyday rough raods riding
