ApexI and Greddy manifolds?
Old Jun 3, 2006 | 02:48 PM
sohcT's Avatar
Default ApexI and Greddy manifolds?
I recently noticed that my sohc ApexI turbo manifold developed a small crack. I have access to a Greddy manifold. Will my Apexi turbo bolt up to a Greddy manifold?
Old Jun 3, 2006 | 03:15 PM
RedEj8's Avatar
Default Re: ApexI and Greddy manifolds? (sohcT)
What kind of turbo is it?
Old Jun 3, 2006 | 03:19 PM
sohcT's Avatar
Default Re: ApexI and Greddy manifolds? (reddohcvtec)
AX53 B60 P18. The one that came with the Apexi sohc turbo kits.
Old Jun 3, 2006 | 03:49 PM
Soccerking3000's Avatar
yea i believe they havea common t2 flange
Old Jun 3, 2006 | 03:56 PM
sohcT's Avatar
Default Re: ApexI and Greddy manifolds? (Soccerking3000)
Thats what I thought. Now the Greddy mani has threads in it to bolt up the turbo correct?
Old Jun 4, 2006 | 06:12 AM
right it has studs
Old Jun 4, 2006 | 08:50 AM
nelsmar's Avatar
i used an apexi mani, w/ a T28(similar turbo). should be a common T2 flange! i dont know about placement of turbo though downpipe might not bolt up right, and put it at a weird height?
Old Jun 4, 2006 | 11:17 AM
p0gi's Avatar
Default Re: (nelsmar)
My apexi manifold did the same thing and I bought a greddy manifold to replace it. The problem is that the studs on the IHI turbo come out of the turbo and the nuts sit above the flange on the apexi manifold, whereas on the greddy manifold the studs come out of the manifold side and the nuts sit under the flange of the turbo. You would only be able to drill out three of the stud holes on the turbo also because one of the holes would end up inside the dp elbow. I would see if you could find someone to weld the manifold and fix the crack, or find an aftermarket manifold. I ended up just getting a gt28r turbo, to mount to the greddy manifold.
Old Jun 11, 2006 | 08:45 AM
oscarmayer's Avatar
have a professional shop weld the crank.
what abotu gettign it repalced? i'm sure it has some sort of warranty. msot manifolds have lifetime warranty.
sohcT
Aug 14, 2007 03:14 PM
carma42
Jul 5, 2006 08:11 PM
blackdelsolsi
Sep 7, 2003 06:01 PM
wrXtian
Mar 23, 2003 03:37 PM
itr449
Oct 29, 2002 11:35 AM
