anyone know how to clean a cf hood?
Old Jun 3, 2006 | 02:06 PM
thegreat0ne's Avatar
Default anyone know how to clean a cf hood?
well i just bought a used cf hood. can someone show me how to clean the hood? beside just washing it?
Old Jun 3, 2006 | 02:08 PM
E46Kid's Avatar
soap and water, by the way looks like ur hood is fading
Old Jun 3, 2006 | 02:37 PM
20civic00's Avatar
Default Re: (EkSi)
cleaning it washes off all the road dirt, but it looks like your hood is fading, and you can't just "wash" it off. Your goin to have to take it to a body shop and have them redo the clear cloat finish on it. Then it will be just like new
Old Jun 3, 2006 | 02:59 PM
spoonracer84eg's Avatar
Default Re: (20civic00)
fading
Old Jun 3, 2006 | 03:11 PM
themorphious's Avatar
Default Re: (spoonracer84eg)
you oculd also try a turtle wax rubbing compound and then a finishing wax to get it back shiny after buffing some of that haze off..........try that first......maybe save some money...
Old Jun 3, 2006 | 03:33 PM
be8teensee1's Avatar
Default Re: (themorphious)
i just did one that was faded like that i just buffed it using rubbing compound "3m" and then finished it with swirl mark remover and it looks brand new
Old Jun 4, 2006 | 12:10 AM
Default Re: (be8teensee1)
yeh i buffed it already. the shitty picture was when i first got. then my friend buffed/waxed it, but then it wont come out. how much would a shop charge me for putting a new clear coating?
Old Jun 4, 2006 | 01:06 AM
Leo C's Avatar
Night Owl
Default Re: (thegreat0ne)
there was a writeup for a buffing process for cf hoods in the a/c forum not too long ago..
Old Jun 4, 2006 | 03:11 AM
hnp5's Avatar
Default Re: (shutupnskate)
if u gonna go thru all that trouble just buy a new one...
Old Jun 4, 2006 | 08:37 AM
20civic00's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by be8teensee1 &raquo;</TD></TR><TR><TD CLASS="quote">i just did one that was faded like that i just buffed it using rubbing compound "3m" and then finished it with swirl mark remover and it looks brand new </TD></TR></TABLE>
I don't think waxing and buffing it will last very long...you'll have to do it probably once a month. Just spend the money and get it refinished. Then u won't ever have to worry about it fading again... it will pay for itself after awhile if u think about your time and materials put into buffing the hood once a month... i had a local body shop here charge me $250 to refinish mine, looks brand new when done, no scratches whatsoever, and will last me for as long as I have the car.
Old Jun 4, 2006 | 10:08 AM
i live in southern california. i dont know a body shop that does hood. do you know one down here?
Old Jun 4, 2006 | 10:12 AM
Archidictus's Avatar
Unceasing Measure
Instead of going through the trouble, just have it painted to match your car. Then you get the weight savings and the OEM look.
Old Jun 4, 2006 | 10:27 AM
jerbear!'s Avatar
if you do end up refinishing it, then make sure you garage your car instead of letting in bake in the heat all day
Old Jun 4, 2006 | 10:34 AM
tha_badguy's Avatar
my bros hood was worse then that
now it looks brand new
if ur gonna do it _ do it right
buffing & waxing is what people say that dont kno any better
the type of person who still uses those cheap 20 polishers n expects to get results
its goes much deeper than that
instead of buying a new hood or taking it to a body shop
u can buy urself a nice circular polisher
with all the right pads & compunds for under $200
then u can give ur hood & car a mirror finish
Old Jun 4, 2006 | 10:47 AM
Default Re: (tha_badguy)
can you explain how you did? what kind of compounds did you use? buy a new one would sorta be out of the question because i dont have enought money to buy a brand new vis cf.
Old Jun 4, 2006 | 10:48 AM
E.46's Avatar
y not just reclear it? only run about $75-100 bux
Old Jun 4, 2006 | 10:55 AM
Default Re: (visionpromo)
how do you reclear the hood? do i need a professional? and where?
Old Jun 4, 2006 | 10:59 AM
E.46's Avatar
I would take it down to a local body shop, have em of course look and if they can do it let them do their magic. I had a friend that had the same prob on a 96 coupe and he took it and had it recleared for $85 bux and it looked brand new.
Old Jun 4, 2006 | 11:00 AM
JasonGhostz's Avatar
Default Re: (Archidictus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus &raquo;</TD></TR><TR><TD CLASS="quote">Instead of going through the trouble, just have it painted to match your car. Then you get the weight savings and the OEM look.</TD></TR></TABLE> (My Vote)
... and it'll make it less likely that someone will want to snake your ****. You can probably get it painted for less than the cost of buying a Buffer, Discs, Compounds, etc... You might even be able to paint it yourself...
https://honda-tech.com/zerothread?id=1543973
https://honda-tech.com/zerothread?id=1010242
https://honda-tech.com/zerothread?id=692532
https://honda-tech.com/zerothread?id=1590721
https://honda-tech.com/zerothread?id=1208538
JMHO...
JasonGhostz
Old Jun 4, 2006 | 11:03 AM
E46Kid's Avatar
Default Re: (JasonGhostz)
Did this to my hood
Old Jun 4, 2006 | 11:39 AM
RocknRon's Avatar
Default Re: anyone know how to clean a cf hood? (thegreat0ne)
Buff it out with Meguiar's #49 Heavy Duty Oxidation Remover or
3M Marine Fiberglass Cleaner and Wax
Desigend to remove LIGHT to MEDIUM oxidation, clean polish and protect fiberglass/gelcoat.
PART#
09009 - 16oz.
09010 - 32oz.
09011 - 1 gallon
3M Marine Fiberglass Restorer and Wax
Designed to remove HEAVY oxidation, chalking, fading, minor scratches, rust and exhaust stains; plus provide protection on fiberglass/gelcoat.
PART#
09005 - 16oz.
09006 - 32oz.
09007 - 1 gallon
3M Marine Protective Liquid Wax
Provide high gloss and protect fiberglass/gelcoat, marine topside paints, painted aluminum and marine metal parts. A special formulation which uses reactive chemistry and actually bonds to the boats surface to provide a durable protective surface.
PART#
09026 - 16oz.
09027 - 32oz.
Modified by Curry king at 12:50 PM 6/4/2006
Old Jun 5, 2006 | 05:49 PM
okay. thank you for the suggestions guys. i think im gonna do the kurry king's way or just go to a shop if i have the money.
Old Jun 5, 2006 | 09:12 PM
revautousa's Avatar
I have buffed out hoods like that. Maybe you just need some more elbow grease, some power tools, or bring it by the shop
Old Jun 5, 2006 | 09:14 PM
revautousa's Avatar
I know its not CF, but it gives you idea of what can be done.
Old Jun 6, 2006 | 01:05 AM
anyone knows a shop that does hood? in OC?
