VTEC Troubleshooting
Old Apr 14, 2002 | 11:20 PM
Kamin's Avatar
Default VTEC Troubleshooting
Ok, I have noticed ALOT of people recently asking about why their vtec isn't working. I'm just going to do some of the basic steps in checking to see why the **** vtec isn't working .
1) Oil level, its gotta be FULL. I'm talking at the upper mark on the dipstick.
2) Solenoid, Ok this is a 2 parter. A) take a wire (any wire) disconnect the grey plug on the vtec solenoid and touch the wire to the pos. battery terminal and the solenoid side of the grey 1 pin connector. there should be an audible click from the solenoid. B) If A checks out, remove the solenoid and clean the filter screen. (self explanatory)
3) Speed, the car must be going over 10 mph so the spedo must be working. that means the VSS has to be working. vtec is temperamental isn't it?
4) more oil, check the oil pan. if its dented POUND IT OUT!. this is why mine wasn't working. the pan was dented in far enough to hit the oil pickup for the pump to cause low pressure situation in the head, no pressure no vtec.
5) ECU Swap out to another ECU that you KNOW vtec works on.
6) Car must be at I belive its 80 degrees or higher so let car get to a normal operating temprature.
7) If none of the above work, you might want to pull the solenoid off the head, remove the solenoid filter and verify the piston moves freely.
Thats a basic troubleshoot for it. if i missed anything or got anything wrong just reply and ill change the info.
If you go through all this and it still doesn't work its oil pressure (the pump) or wiring related. so check all the wires for vtec.
Thats it i hope it helps some people.
Joe
[Modified by KAMiN, 5:45 PM 6/5/2002]
Old Apr 14, 2002 | 11:43 PM
Katman's Avatar
Default Re: VTEC Troubleshooting (KAMiN)
Joe
you left out temperature.
The car has to be at a normal operating temperatures in order for vtec to kick over, as well.
Old Apr 14, 2002 | 11:52 PM
Kamin's Avatar
Default Re: VTEC Troubleshooting (Katman)
d'oh
Thanks katman i knew i forgot somthing.
Old Apr 15, 2002 | 01:40 AM
Katman's Avatar
d'oh
np.
Old Jun 1, 2002 | 12:15 AM
garagespecial
Guest
Posts: n/a
gotta have a vtec motor as well
Old Jun 1, 2002 | 12:26 AM
gsrvx's Avatar
New User
Default Re: VTEC Troubleshooting (garagespecial)
Old Jun 1, 2002 | 05:09 PM
mugenracer's Avatar
i thought the speed had to be 19mph, plus the oil level doesnt have to be full, before i realised how much oil i was using i was running around for a week with the oil level not even registering on the dipstick, took almost 3/4 litre to bring it up to full, but the engine/vtec was working perfectly. I think the actual temp has to be 74 degrees before it will work.
Old Jun 1, 2002 | 09:55 PM
dkay040's Avatar
Default Re: VTEC Troubleshooting (mugenracer)
At a pre-designated RPM, if and only if there is enough oil pressure , the CPU activates a solenoid. This causes a pin to lock the intake valves together creating a sudden jump in acceleration. To activate the second stage at 2500 rpm(both valves opening), oil pressure is diverted into a channel that drives a pin which connects intake valve rocker #1 with #2. Now, both intake valves are being operated in unison. This is perhaps not quite as ideal as a little valve stagger (as seen in the DOHC VTEC apps), but sufficient enough for good power.
To enter the third stage, at 6000 rpm, oil is now allowed into a second channel connecting all the rocker arms. This oil drives a pin which connects the linked #1 and #2 rockers to the center lobe actuated #3 rocker which is, of course, the high lift and duration mode.
Frankly, the implementation, from an engineering standpoint, is absolutely brilliant.
Old Jun 2, 2002 | 12:07 AM
Kamin's Avatar
speed dosent matter, its just the fact that the spedo has to be working.
and for the oil, it can work at halfway up the dipstick, but its a good general rule to make sure its at the upper mark before you do anything drastic (like removing the solenoid)
Old Jun 2, 2002 | 12:41 AM
tinkerbell's Avatar
Default Re: VTEC Troubleshooting (dkay040)
seems you are brilliant too
never had it explained better...?
t..
(PS is this true? it uses pins? are you talking about VTEC? isnt the third rocker a lost motion assembly?)
Old Jun 2, 2002 | 04:53 PM
dkay040's Avatar
Default Re: VTEC Troubleshooting (tinkerbell)
yes it uses pin do u think i would just waste my time writing that for the hell of it
Old Jun 2, 2002 | 05:58 PM
tinkerbell's Avatar
ROFLMAO!!!!!!!!!!!!!!!!!!!!!!!!!
maybe if YOU wrote it...
http://integra.vtec.net/engine/vtec.html
cya,
t..
Old Jun 2, 2002 | 10:06 PM
Kamin's Avatar
cya,
t..
haha OWNED
dont post other peoples stuff
Old Jun 2, 2002 | 10:07 PM
MikeSarr_GSR's Avatar
actually, you didnt forget.
Old Jun 2, 2002 | 10:10 PM
Kamin's Avatar
Default Re: VTEC Troubleshooting (MikeSarr_GSR)
i edited it and put it in there
Old Jun 3, 2002 | 10:09 PM
crxfactor1991's Avatar
what about throttle position?
Old Jun 3, 2002 | 10:22 PM
tinkerbell's Avatar
Default Re: VTEC Troubleshooting (crxfactor1991)
no, VTEC remains engaged whilst TP is where-ever,
for example, backing off down a hill at 6500rpm with throttle closed...
then boot it to WOT and VTEC is already engaged and you will nail it to redline...
is this what you sort of meant?
so i guess that throttle position does not have a effect on VTEC except for it needing to be open before you can get to VTEC
UNLESS you downshift into VTEC...
so actually, no, throttle position does not affect VTEC?!?!
am i right?
please consider...
t..
Old Jun 3, 2002 | 11:54 PM
kinesistech's Avatar
You're right, but I haven't seen anyone mention the MAP sensor. The car has to be under a load. Thats also why theres no vtec with the car sitting.
Old Jun 4, 2002 | 12:07 AM
Yo, you must have the good drugs. The both valves always open, not one untill the "1st stage" which doesnt exist, if you actually look at it 2 cam lobes are always touching 2 rockers. Those are typically ALWAYS working. Also, how is it, do you suppose, that you can get three stages of vtec where oil is diverted here and there when there is only one vtec solenoid per engine.
Please explain to me how you get oil to travel selectively around vtec rocker arms pins. Have you ever taken apart a vtec head. I have taken apart quite a few, and I'll tell you, I've only found 1 path for the oil to take and I have yet to see it skip past the center to engage both outside rockers. For what reason somone would want to do this is beyond me since they always work and dont need to be engaged.
Im all about support and helping each other out, but if you dont know dont go and undo the help that others have provided.
Old Jun 4, 2002 | 01:01 AM
tinkerbell's Avatar
Default Re: VTEC Troubleshooting (kinesistech)
hey kinesistech!
how goes it??
we are not sure where this guy gets his kicks from but we worked out he copies other peoples stuff and doesnt bother to read it before posting it.
oh well, some people gotta learn the hard way...
anyways,
im not sure i agree on the MAP bit.
the only reason VTEC doesnt engage whilst stationary is because of the VSS rule.
im pretty sure i have seen no litrature that links MAP to VTEC.
as i stated above TPS is not an VTEC input as you can be coasting down hill at 6500rpm and still have VTEC engaged, you dont get the sound, but when you snap hte throttle open, it hits straight up.
so i dont think VTEC disengages because of no load circumstances...
that is, VTEC engagement is not load dependent.
have i mis-interpreted what you were saying???
t..
Old Jun 4, 2002 | 01:54 AM
spoon_ek9's Avatar
i think he mess the 3 stage sohc vtec with dohc vtec
Old Jun 5, 2002 | 12:17 AM
You read me right, I think some one should try it Im not %100 postive though. put your VSS in a drill and disconnect MAP. I guess with any check engine lights the vtec doesnt work anyway huh. Oh well.
Spoon, no he is wrong. What he wrote makes no sense.
[Modified by kinesistech, 9:20 AM 6/5/2002]
Old Jun 5, 2002 | 01:24 AM
Kamin's Avatar
not true. only certan ones will disable vtec.
Old Jun 5, 2002 | 06:01 AM
dbman96's Avatar
New User
Here's another fun one - disassemble the solenoid assembly and make sure the piston slides FREELY - last night I discovered that mine was completely bound up in one position.
Old Jun 5, 2002 | 08:59 AM
B_CRUZ!'s Avatar
it matters. because last night i adjusted my tps "wrong" and now my vtec doesn't cross over.
