GSR swap into a LS... help...
okay we swap a gsr into a ls and wire the v-tec wires... but it throwing code 21 and v-tec won't kick... need some suggestion...any help will be nice... might of miss some wires... help...
check the pin placement in the harness, it could be in the wrong pin
a code 21 is the vtec soleniod vale which is the gray plug off of the vtec soleniod, check your connections and if the wire is recieving a signal
gsrauto98
May 28, 2010 12:04 PM
