Searched: Window tab alignment 90 CRX
Hey guys,
The window tabs on my passenger side window fell off and I need to get them back on there. I've searched and looked in my repair manual and have found nothing as to do if this happens. Does anyone have the measurements for where the tabs are supposed to be in on the window?
Thanks!
Thanks!
The plastic tabs that are epoxied to the window itself at the bottom. They have bolts that connect them to the regulator, but they are pretty much connected to the window. They don't have a number on that diagram.
just line it up with the regulator or if your able to tell where they were before then just use some kind of silicone adhesive. mine fell off too and i just stuck it back where it was and amazingly 16 year old glue still somewhat stuck to the glass and put it back and never had a problem
I've cleaned off the glue so I can reapply new glue so this doesn't happen again. I want to do it right. No measurements???
I'm sure this has happened to more than myself and dod...
Took apart driver's side door and measured that to get measurements for the passenger side. Here they are...
Red = 13 & 1/2 inches from edge of window
Blue = 11 & 1/4 inches from edge of window
Green = 6 & 1/4 inches from edge of window
Orange = 4 & 5/8 inches from edge of window
These are not EXACT, but they are close enough. I used some stuff called Goop from Advance Auto. I let partially cure then fit the window in and got it snug by rolling it all the way up so it cured in the right spot. Make sure you clean off all prior adhesive real good beforehand. Hope this helps someone.
I have no idea, the passenger side window was F*d when I bought the car. They look to be held on with some epoxy that the heat didn't like.
Why would you be better off spending $100 on a new window instead of buying a $5-8 tube of epoxy and put the tabs back on? I really doubt I'm the only one this has ever happened to. Oh well, problem solved.
tony007
Jul 15, 2005 12:31 PM
