how to adjust idle
Old Jun 3, 2006 | 09:52 AM
skata89's Avatar
Default how to adjust idle
OK on the screw thats in the IM do you tightn it or loosen it to get a higher idle?
Old Jun 3, 2006 | 10:07 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: how to adjust idle (skata89)
Which car? The idle adjustment screw is on the throttle body.
1) Warm the car to operating temperature.
2) Shut off the car.
3) Disconnect the IACV (Idle Air Control Valve).
4) Restart the car. You may need to press the accelerator. Slowly release until the car idles.
5) Set the idle screw on the throttle body until the car idles at 450 +-50 RPM
6) Shut off the car.
7) Reconnect the IACV.
8) Restart.
9) Check the idle. It should be 750RPM.
10) Clear any CELs for the IACV.
Old Jun 3, 2006 | 10:10 AM
skata89's Avatar
do i just unplug it or do i take it completely of the IM. also how to you clear the cels? and i have the jdm b18c which i think should idle around 900. correct me if im wrong. so what should i set the screw too now? and do i tighten it or loosen it?
Old Jun 3, 2006 | 12:57 PM
mymeatb18
Default Re: (skata89)
just cause its jdm doesnt mean it idles higher. the stock idle for all hondas well at least i know for all the older hondas is 750 whether it be jdm, usdm,edm,ukdm all the same
Old Jun 3, 2006 | 12:58 PM
DC2 Mang's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skata89 &raquo;</TD></TR><TR><TD CLASS="quote">do i just unplug it or do i take it completely of the IM. also how to you clear the cels? and i have the jdm b18c which i think should idle around 900. correct me if im wrong. so what should i set the screw too now? and do i tighten it or loosen it?</TD></TR></TABLE>
just un plug it
to clear the CEL's take the ecu fuse out or disconnect the battery ground for about 15 minutes
Civicfanatic_09
17
Jul 16, 2012 12:04 AM
SilverSellout
12
Feb 27, 2004 12:48 PM
killa_lude
Aug 16, 2003 08:33 AM
