White smoke, help fresh swap
Old Jun 3, 2006 | 07:41 AM
philkehn's Avatar
Default White smoke, help fresh swap
Well i just put a fresh swap into my 88 crx dx, when i turn it on and it idles it goes okay, but when i rev it at high rpms say about 5000, i get thick smoke that is coming outta the tail pipe as well as some water like stuff in a orange brown color....
My ecu only blinks code 14... what could be causing all this smoke?
Old Jun 3, 2006 | 08:01 AM
philkehn's Avatar
could it be coolent or am i running to rich? is this going to hurt my engine i need help baaad, bump
Old Jun 3, 2006 | 08:51 AM
JLefevers's Avatar
Default Re: (philkehn)
did the motor just get rebuilt bc if so it is prolly just burning oil perfectly normal until the rings seal up.
Old Jun 3, 2006 | 09:02 AM
philkehn's Avatar
no rebuild, its a brand new swap well it has like 30000 miles on it but, yea the first time i started it as well as multiple times over it blew out white smoke at high rpms, i took it around the block a couple times and it was still smoking and it started to over heat
Old Jun 3, 2006 | 09:14 AM
superacecardriver's Avatar
Pressure test your system first. Sounds like a headgasket. Could be cracked block. Find your leak. When you overheat your motor your rings collapse and the motor is garbage just for your information.
If it were my motor I would have cleaned that bitch up, rebuilt it and then put it in. Doesn't even take that much time to rebuild.
Old Jun 3, 2006 | 09:24 AM
philkehn's Avatar
takes that much money that i dont have however its under a 100% guarentee so anything wrong with it would be replaced.... however i am pretty sure its not a cracked block for it doesnt leak any anti freeze, on behalf of the white smoke i was told that it could be the oil burning through just getting used to being ran again, ive been told the thing about the head gasket and i have also been told about that it could be coolent, although i have no idea how coolent can even make its way to the exhaust
Old Jun 3, 2006 | 10:25 AM
Voodooboy520's Avatar
Okay
It smells sweet, right? If so, and its white (not blue) then its coolent. Sounds like a blown head gasket. Not really hard, just tedious.
https://honda-tech.com/zerothread?id=468260 Codes
Your 14 is the EACV, make sure its wired right and such. And now that I think about it, the EACV has coolent running through it. Check that.
Old Jun 3, 2006 | 11:08 AM
philkehn's Avatar
is there any way that you could absolutly tell that its the head gasket cuz if not and i end up changing it out thats alot of work for nothing
Old Jun 3, 2006 | 11:13 AM
Default Re: (Voodooboy520)
think about it, your cylinders are surrounded by coolant. Cracked sleeves or leak in the headgasket, coolant can enter the chamber and poof thats how it can enter the exhaust. And thats explaining it to you like your three. no offense.
Old Jun 3, 2006 | 11:15 AM
philkehn's Avatar
so even though its a fresh swap its not anything that the engine can just push out and there is no other possibilities that it could be?
Old Jun 3, 2006 | 11:21 AM
jacoop86's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philkehn &raquo;</TD></TR><TR><TD CLASS="quote">is there any way that you could absolutly tell that its the head gasket cuz if not and i end up changing it out thats alot of work for nothing</TD></TR></TABLE>
do a leakdown test. heres a write up:
http://www.c-speedracing.com/h...n.php
"if you remove the radiator cap and air bubbles appear in the coolant, then your headgasket is blown."
Old Jun 3, 2006 | 11:34 AM
bag's Avatar
bag
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philkehn &raquo;</TD></TR><TR><TD CLASS="quote">no rebuild, its a brand new swap well it has like 30000 miles on it but, yea the first time i started it as well as multiple times over it blew out white smoke at high rpms, i took it around the block a couple times and it was still smoking and it started to over heat</TD></TR></TABLE>
no one knows the real mileage or history with these motos from japan...it could have 150k miles and been taken to 8000rpm every single day for all you know
Old Jun 3, 2006 | 11:43 AM
philkehn's Avatar
actually from what ive been told, do to the amount of space in japan as well as pollution laws they will be fined for any engine over 30000 miles so they have to discard them so we buy them, but as far as the 8000 rpm everyday that could be very true
Old Jun 3, 2006 | 11:59 AM
mar778c's Avatar
Community Builder
Community Influencer
Sounds like a blown headgasket. Not difficult to replace just get a helms or haynes manual. They'll walk you right through it.
Old Jun 3, 2006 | 12:03 PM
Dont be ignorant - not everyone drives thier car exactly x miles per day. I'm sure there are a ton of engines with MUCH more than 30k miles on them because either A) thier all highway or, B) They liked the car and kept it more. Just remember, your buying a used engine AS-IS.
Old Jun 3, 2006 | 02:23 PM
philkehn's Avatar
I agree, would the head gasket being blown have anything to do with the performance, also it seems the more i drive it the less it smokes, could it have anything to do with the fuel being to rich?
Old Jun 3, 2006 | 04:19 PM
KURUPTinc's Avatar
Default Re: (aallbbeerrtttttt)
Listen all you gotta do is buy/rent a block tester. They sell it at any auto place its just a blue liquid that you put in special turkey bayster thing and you let your car warm up then undo the radiator cap and put one end by the radiator and if it picks up hc's in your system it will turn green , meaning blown gasket or cracked block. I surely doubt the block is cracked cause then youd have coolant and oil mixture.
Old Jun 3, 2006 | 06:01 PM
philkehn's Avatar
thanks for the help im glad i didnt get to work on the head gasket cuz theres no more smoke
By the way if you think im begging for answers you should stop thinking so high of your self cuz what you told me was wrong... unfortanatly i guess. Also questions should lead to answers and if you cant give me a good one and want to leave a smart *** comment again just like all you idiots find a new thread, im better off without you idiots
itr590
Nov 30, 2007 03:25 PM
itr590
Nov 30, 2007 12:41 PM
B20badboy
Jan 12, 2006 08:59 AM
Teal95Coupe
Mar 29, 2005 07:50 PM
sxecustoms
Jul 29, 2004 03:36 PM
