can i run spark plug 6 heat range on turbo safe??
Old Jun 2, 2006 | 11:58 PM
eg:R's Avatar
Default can i run spark plug 6 heat range on turbo safe??
i had my car tune on 6 heat range plugs(gap 32) and now ichang e plugs to 7heat range(gap28). now my car part throttle run like **** and my temp seem to raise at times. do i need another tune or just switch back to my old plugs.
Old Jun 3, 2006 | 10:22 AM
eg:R's Avatar
bump
Old Jun 3, 2006 | 01:22 PM
RedEj8's Avatar
Default Re: (eg:R)
Well, if ur car was tuned using 6 range plugs then u should stick with those. Any changes u do to ur motor will change the tune.
Old Jun 3, 2006 | 01:36 PM
EG civic's Avatar
Default Re: (reddohcvtec)
If u were running 6 heat range plugs with no problems y switch to 7? I say stick with 6.
Old Jun 3, 2006 | 04:44 PM
y7turbo's Avatar
Default Re: (EG civic)
do some reading on how to read pugs, go make a run to the top of 3rd gear and read the plugs. you will know what to look for if your plugs are to hot of a heat range.
i run ngk 6 on my sohc at 5 psi but will go to the 7's when i turn up the boost.
Old Jun 3, 2006 | 05:36 PM
eg:R's Avatar
i know that i need to run colder plugs. at the time of the tune i did not have anything but 6 heat plugs. now i want to change to 7's. tune it to 400hp w/ 6's.
staticchmbr
Jan 14, 2006 07:29 AM
tuoniz
Aug 16, 2005 11:30 AM
r7
Aug 26, 2003 05:18 AM
vha27
Feb 14, 2003 08:11 AM
808eg6
Jan 25, 2002 07:03 AM
