Pic request... 92-93 fog switch wiring
Got my fogs the other day, but can't seem to find the wiring for the switch under the left tweeter assembly. I looked and digged under there, but no luck. I found a piece of wiring harness with a blue cover over it (flat and Blue). I don't think this is it, need pics of the actuall wiring w/o switch attached. Thanks. 92 -93 Prelude
is there any way to not have fog switches and just hook it up together with the headlights where whenever the headlights are on the fogs are on? and would it be easy to do?
You could splice the foglights straight into the headlight wiring with a fuse, but I think its a bit unsafe. I am running my fogs like that for about 8 months now so I think its ok. But many will probably tell you itsnot safe since it takes a good amount of power to run the fogs and headlights together.
Damn, I'm about to rip apart my whole dash to get to this harness. I cant locate this piece of sh*t. I tried from underneath, uptop, dug through the small hole by the tweeter, and nothing. I searched this forum, and nothing; can't find what I need. Any1 with pics please?
Modified by street_ride14 at 7:55 PM 6/3/2006
take out your driver's seat so you can lay down and look up.
It makes it a bit easier.
If you can figure out the wiring, you can splice it off of your cruise switch wiring so it works like it is supposed to.
oceanbeast
11
Jul 19, 2011 04:44 PM
I Love My 4 door
Nov 8, 2009 03:59 PM
