tachometer help
autometer. just a guess.
http://www.autometer.com/
http://www.autometer.com/tech_...sid=8
want me to install it for you too?
I could give u instructions right now:
Red= switched power source(black/yellow wire under steering wheel.this is the ignition switch wire)
Green=rpm lead( blue wire on two-wire dizzy plug
Black=ground(self explanatory
White=tach light(I wired this into my headlight harness.its a red/yellow wire at the headlight.this way the light only goes on when u hit yur low-beams. When you hit high beams your low's stay on too)
red/black instead of red/yellow IMO. This wire turns on parklight and can be found either at the switch or driver's kick in the harness going to the back of the car.
Tach light will turn on when parklight is on.
Suck my DX
11
May 12, 2007 01:13 PM
CBR_15
Nov 29, 2006 10:42 PM
Vtakkk
Mar 3, 2006 03:35 PM
slammedef06
Jan 24, 2005 01:12 PM
