rear disk conversion for ek?
Old Jun 2, 2006 | 01:05 PM
freakasis's Avatar
Default rear disk conversion for ek?
iv read a few walkthroughs and they said conflicting things...
what LCAs do i need?
and what prop valve do i need?
if anyone knows where there is a GOOD walkthrough with lotsa info that would be awsome!
thanx
rob
Old Jun 2, 2006 | 01:13 PM
sol2hatch's Avatar
Default Re: rear disk conversion for ek? (freakasis)
look in the FAQ, There is an *** load of brake swap articles in there. Check the one that says EK in the title, he sounds like he knows whats up.
Old Jun 2, 2006 | 01:20 PM
Targa250R's Avatar
be professional
You keep your stock LCAs.
Old Jun 2, 2006 | 02:59 PM
BlueIntegraBoy's Avatar
Stock LCAs are fine. The HB prop valve is the same as the Si, but you will not need them for the rear disks.
Old Jun 2, 2006 | 05:52 PM
broketuner-Sol_Si's Avatar
Default Re: rear disk conversion for ek? (BlueIntegraBoy)
i believe the only time you need to change the prop. valve is when you upgrade to teg brakes. I know that the only time you need to change lcas are when you want to add a swaybar or in some retarded cases just to add bling....the oem ones are fine to reuse(I swapped mine out for oem gsr ones in order to run a rear sway bar though). If you plan on doing it all yourself here's my suggestions:
-Buy a shitload of liquid wrench or something similar(I went through almost 2 full cans when I did mine on my eg a couple of weeks ago)
-use a good 1/2" drive socket set(I broke 2 3/8" drives)
-have a good/accurate tq. wrench
-a nice breaker bar using slow preassure works well(I used the bar from he jack)
-have a friend help you out and buy them beer & pizza afterwards
-recheck every bolt you touched and rebleed the brakes at least twice before you drive it.
Old Jun 3, 2006 | 08:34 AM
freakasis's Avatar
thanx....
i am going to be putting ls brakes and a gsr sway bar on the back...does this mean if i use the gsr/ls lcas or the si lcas i will be fine? or are the gsr and si endlinks differant?
Old Jun 3, 2006 | 08:44 AM
.BigSexy's Avatar
most hood white kid
Default Re: (freakasis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by freakasis &raquo;</TD></TR><TR><TD CLASS="quote">thanx....
i am going to be putting ls brakes and a gsr sway bar on the back...does this mean if i use the gsr/ls lcas or the si lcas i will be fine? or are the gsr and si endlinks differant?</TD></TR></TABLE>
I think gsr LCA's will work, I just got omnis, but you cna get GSR lcas for about 30 bucks used....
Old Jun 3, 2006 | 11:05 AM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by freakasis &raquo;</TD></TR><TR><TD CLASS="quote">if i use the gsr/ls lcas</TD></TR></TABLE>
You can't. They aren't long enough. You need '96-00 Civic rear LCAs.
Old Jun 3, 2006 | 11:13 AM
Default Re: (Targa250R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R &raquo;</TD></TR><TR><TD CLASS="quote">
You can't. They aren't long enough. You need '96-00 Civic rear LCAs.</TD></TR></TABLE>
true...I was thinking for an eg when I mentioned the GSRs .
Old Jun 3, 2006 | 12:27 PM
SPD DMN's Avatar
Default Re: (broketuner-egb16a)
Did the swap myself to 94 GSR brakes, you need to keep your stock LCAs from your EK, and I reused my prop valve...
Good luck!
Old Jun 3, 2006 | 10:13 PM
freakasis's Avatar
since i will be using a rear sway bar i guess that means that i will need SI LCAs since i dont think my EX ones have the mounting holes.
thanx all
Stevieherron
Mar 23, 2016 11:57 AM
PardonmyEK9
Jul 9, 2010 07:48 AM
oooblessooo
Mar 1, 2009 04:39 AM
JokerTypeR
13
Nov 14, 2006 05:37 AM
enrique
42
Oct 25, 2003 07:56 PM
