rear disk conversion for ek?
iv read a few walkthroughs and they said conflicting things...
what LCAs do i need?
and what prop valve do i need?
if anyone knows where there is a GOOD walkthrough with lotsa info that would be awsome!
thanx
rob
thanx
rob
Re: rear disk conversion for ek? (freakasis)
look in the FAQ, There is an *** load of brake swap articles in there. Check the one that says EK in the title, he sounds like he knows whats up.
Re: rear disk conversion for ek? (BlueIntegraBoy)
i believe the only time you need to change the prop. valve is when you upgrade to teg brakes. I know that the only time you need to change lcas are when you want to add a swaybar or in some retarded cases just to add bling....the oem ones are fine to reuse(I swapped mine out for oem gsr ones in order to run a rear sway bar though). If you plan on doing it all yourself here's my suggestions:
-Buy a shitload of liquid wrench or something similar(I went through almost 2 full cans when I did mine on my eg a couple of weeks ago)
-use a good 1/2" drive socket set(I broke 2 3/8" drives)
-have a good/accurate tq. wrench
-a nice breaker bar using slow preassure works well(I used the bar from he jack)
-have a friend help you out and buy them beer & pizza afterwards
-recheck every bolt you touched and rebleed the brakes at least twice before you drive it.
thanx....
i am going to be putting ls brakes and a gsr sway bar on the back...does this mean if i use the gsr/ls lcas or the si lcas i will be fine? or are the gsr and si endlinks differant?
most hood white kid
Re: (freakasis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by freakasis »</TD></TR><TR><TD CLASS="quote">thanx....
i am going to be putting ls brakes and a gsr sway bar on the back...does this mean if i use the gsr/ls lcas or the si lcas i will be fine? or are the gsr and si endlinks differant?</TD></TR></TABLE>
I think gsr LCA's will work, I just got omnis, but you cna get GSR lcas for about 30 bucks used....
be professional
Re: (freakasis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by freakasis »</TD></TR><TR><TD CLASS="quote">if i use the gsr/ls lcas</TD></TR></TABLE>
You can't. They aren't long enough. You need '96-00 Civic rear LCAs.
Re: (Targa250R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R »</TD></TR><TR><TD CLASS="quote">
You can't. They aren't long enough. You need '96-00 Civic rear LCAs.</TD></TR></TABLE>
true...I was thinking for an eg when I mentioned the GSRs .
Re: (broketuner-egb16a)
Did the swap myself to 94 GSR brakes, you need to keep your stock LCAs from your EK, and I reused my prop valve...
Good luck!
Good luck!
since i will be using a rear sway bar i guess that means that i will need SI LCAs since i dont think my EX ones have the mounting holes.
thanx all
thanx all
oooblessooo
03-01-2009 04:39 AM
enrique
42
10-25-2003 07:56 PM
