Key Duplication
A bunch of dirty ******s stole my key and I need another for my 09 Civic (only got one with the car), and have been informed the key has a transponder so it cannot be duplicated conventionally. The dealer wants $40 for a new key, is there a less expensive option?
There isn't a transponder inside of the key. That's a load of pucky. You could get a blank key off of a website like h and a, or even eBay a blank, but going to a hardware store that does key making (like ACE or True Value or Home Depot), and have one made there.
No, I'm pretty sure the dealer is at least somewhat right. I've been told elsewhere the key has a "chip". I tried having two copies made at Walmart, and both didnt work. They would turn on the radio etc, and the engine would even turn over, but the car wouldnt start.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toyomatt84 »</TD></TR><TR><TD CLASS="quote">There isn't a transponder inside of the key. That's a load of pucky. You could get a blank key off of a website like h and a, or even eBay a blank, but going to a hardware store that does key making (like ACE or True Value or Home Depot), and have one made there.</TD></TR></TABLE>
sorry, but you're wrong.
for OP, go to the dealer, give them your VIN and proof that you own the car, they will make you copies, it's around $40.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fventura03 »</TD></TR><TR><TD CLASS="quote">sorry, but you're wrong.
Well, if I am, then how come I made a spare key for myself, and it works.
You don't need to jump down my throat, bud. I've had keys work, the way I mentioned.
</TD></TR></TABLE>Well, if I am, then how come I made a spare key for myself, and it works.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toyomatt84 »</TD></TR><TR><TD CLASS="quote">Well, if I am, then how come I made a spare key for myself, and it works.
You don't need to jump down my throat, bud. I've had keys work, the way I mentioned.</TD></TR></TABLE>
What year and models? Do they have aftermarket alarm systems?
i've tried as well, it only worked to open doors, trunk. you must have some remote start or something that bypasses it. if not, i feel sorry for you. i believe that the reason most em2/ep3/dc5's don't get stolen is because of this security feature.
not flaming, just don't want people thinking the wrong stuff.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fventura03 »</TD></TR><TR><TD CLASS="quote">i've tried as well, it only worked to open doors, trunk. you must have some remote start or something that bypasses it. if not, i feel sorry for you. i believe that the reason most em2/ep3/dc5's don't get stolen is because of this security feature.
not flaming, just don't want people thinking the wrong stuff.</TD></TR></TABLE>
I can applaud your effort on not wanting the wrong info. being tossed out, truly I can. I'm in the same boat, in all honesty.
As far as the key, I just got back from double testing it, and you're right it didn't start the ignition. It'd get to the 3rd setting and just click. Didn't know that it would just sit there.
not flaming, just don't want people thinking the wrong stuff.</TD></TR></TABLE>I can applaud your effort on not wanting the wrong info. being tossed out, truly I can. I'm in the same boat, in all honesty.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nandy »</TD></TR><TR><TD CLASS="quote">there are other ways to program them rather then having the dealer do it ... </TD></TR></TABLE>
I dont think so. How???
My key does not look like that, yet it does have a chip.
So you guys are saying there is really no other way to have a copy made than go to the dealer? If I buy a blank online will the dealer cut/program it for free or what?
Guys,
I work in a Honda Parts Department. Yes the 01 civs have a chip Key. The first year chip key was the 97 prelude. Then in 98 they came on the Accords.Then the Odyssey's in 99. Then The S2000 in 2000. Then The civs in 01. Then the CR-V's in 02. The Pilot in 03. .
toyomatt84,
Give me your Vin and I can tell you if yours is or not!! Is your Tenths degit in your Vin a 1 or a Y??
toyomatt84,
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rennen »</TD></TR><TR><TD CLASS="quote">im pretty sure that the 03-05's have a key like this:
which have a chip inside.
whereas the 01-02's have the conventional ones that dont have the chip.</TD></TR></TABLE>
I have an 03 lx. and my key does not have the lock and unlock buttons on it, but I have power locks
My Bad........
</TD></TR></TABLE>My Bad........
That key comes with the 03 and up Accords lx and ex models. Also 01 and 02 do have a chip. Part number for them is 35113-S84-A02 or 35113-S84-A01. Same key as the 98-02 Accords use!!
well, its not exactly chip per say...If it were chip it would need DC power source to power chip.
But the keys do not have batteries inside them...01-02 keys...
Its actually a voltage divider...when the key is inserted, the ECU measures the voltage drop across the key and matches the output with preset value...when it matches then ECU okays the key and ignition good....
Why it is cheaper and effective method of not mixing and copying keys...dealers can charge more if you lose your key...compared to going to a hardware store for $3...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nhsledding »</TD></TR><TR><TD CLASS="quote">Guys,
toyomatt84,
Give me your Vin and I can tell you if yours is or not!! Is your Tenths degit in your Vin a 1 or a Y??</TD></TR></TABLE>
Just a question, typically what does the dealer charge for a replacement key? 01 civic ex.
toyomatt84,
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by devani »</TD></TR><TR><TD CLASS="quote">well, its not exactly chip per say...If it were chip it would need DC power source to power chip.
Sure they do, they have a transponder chip, dont need a battery. If you dont beleive me split one of the keys apart.
Straight from the factory service manual:
When the key is inserted into the ignition switch and turned to the on position, the immobilizer control unit sends power to the transponder in the ignition key. The transponder then sends a coded signal back to the immobilizer control unit which then sends a coded signal to the pcm.
The dealer I work at charges around 80.00. key 39.43 retail. the labor is a 1/2 hr. The shop rate is 78 HR. The tech gets paid 1/2 Hr shop time too program the Key.
Some dealers might be more or less.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca »</TD></TR><TR><TD CLASS="quote">Sure they do, they have a transponder chip, dont need a battery. If you dont beleive me split one of the keys apart.
http://www.nvo.com/natl/cookiesnotice/
Like I said its not a chip per say...I am saying its not your typical chips that we are familiar with...Its a system or chip like they mention it...
this website has replica keys....I did not actually test them....
http://www.nvo.com/natl/displa...13216
cheaper too...$14.99
96accordlxf22b2
10
Apr 18, 2006 06:46 PM
_Spugen_
14
Jan 17, 2005 01:49 PM
2003, 35113s84a01, 35113s84a02, acura, alexandria, chip, copyer, depot, duplication, home, honda, key, keys, prelude, replica, tl, va
