Honda S2000 Honda S2000
Key Copying
Old Oct 27, 2003 | 05:28 AM
jolt-tsp's Avatar
Default Key Copying
Why is it about the OE keys that make it so only they can start the engine? There's only one metal contact from the key touching the car, so it can't really be running a code. Is it just a resistor or something inside the key? If so, does anyone know the ohmage? I don't really want to chop up my only key to find out.
Old Oct 27, 2003 | 07:17 AM
munckee's Avatar
There is a computer chip inside the plastic part of the key that is coded to match your ECU. If you remove the chip, the key won't start the car. I believe it can still be used to unlock the doors, etc. though.
Old Oct 28, 2003 | 09:02 AM
99integralsturbo's Avatar
Default Re: (munckee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by munckee &raquo;</TD></TR><TR><TD CLASS="quote">There is a computer chip inside the plastic part of the key that is coded to match your ECU. If you remove the chip, the key won't start the car. I believe it can still be used to unlock the doors, etc. though.</TD></TR></TABLE>
yep
Old Oct 28, 2003 | 09:12 AM
jolt-tsp's Avatar
Default Re: (99integralsturbo)
Gotcha. I found a ittle more info, I beleive it generate RF when powered and thats what is read. Thanks for the input
Kuroneko
Honda CR-V & Element
May 26, 2019 11:36 PM
95LSv
Honda Civic (2001 - 2005)
Mar 28, 2010 12:51 PM
ac_attak
Jun 21, 2006 08:33 PM
rtcpenguin
23
Jun 6, 2006 07:37 AM
ErniePower_3
Dec 4, 2005 07:09 PM
