type r/sir-g front end?!..
now im debating from the two, what exactly is the difference from the two? type r seems more pricey then the sir-g. But they seem to look the same.
type r headlights - black housing
sir-g headlights - chrome housing
front lip is different
edit: here is a good link
https://honda-tech.com/zerothread?id=1537252
and another
https://honda-tech.com/zerothread?id=1533122
and another
nope...except that the itr one may look better due to the fact it has the black housing headlights..but you can always swap out the sir-g ones for the black housing ones, or even the HID ones.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egg6vtak »</TD></TR><TR><TD CLASS="quote">Is there any advantage on having either one?</TD></TR></TABLE>not unless you get the HID ITR front end. other than aesthetics (most feel black headlights look better than the chrome) there is no advantage to having one over the other.
pretty much the same, so the sir-g is cheaper, but then again you'll end up spending extra $$ just to get black housing and a lip, which will ultimately cost more then the type r or around the same? i assume, so might as well go with a type r then right?
type r is better then sir-g. reason why is becuase the type r headlight is black housing. cost more then the sirg. Sirg headlight is clear price is lower the the type r.. also sir doesnt come with the jdm itr lip, and the the type r comes with a lip
if you do get the sir-g, there is a writeup on this board for how to make DIY black housing headlights from chrome SIR-G headlights.. other than that you won't get the HIDs or the lip
yes you can, but jdm itr lip cost 250 or even more
hmo price for jdm front end
type r 1650 with black housing and lip
sirg 1300... no lip, no black housing
what do you prefer? no doubt type r is a better deal cuz black housing headlight cost way more the sirg but is up to you i got a type r and i love black housing, sir g doesnt look right
yah i thought so too, cuz ive been seeing the sir-g front ends, and they don't seem to look right. Im going with type r front end anyway, just wants some assurance on what my option is from the two. Thanks!
installed is gonna be bitch. if you have time and skills you can do it on your own. i see 2 write up on it so far
https://honda-tech.com/zerothread?id=1346217
http://www.masetuning.com/jdmc....html
i got my done from a friend.. welded and did a pretty clean job. but good luck to ya pal..
btw where you gonna buy your front end from?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trick_db »</TD></TR><TR><TD CLASS="quote">yes you can, but jdm itr lip cost 250 or even more
</TD></TR></TABLE>you can get a JDM ITR replica from jdmshit for $145 shipped
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shutupnskate »</TD></TR><TR><TD CLASS="quote">if you do get the sir-g, there is a writeup on this board for how to make DIY black housing headlights from chrome SIR-G headlights.. other than that you won't get the HIDs or the lip</TD></TR></TABLE>
type r with hid cost 2150. and is not cheap. stock type r front end good already
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .brian. »</TD></TR><TR><TD CLASS="quote">you can get a JDM ITR replica from jdmshit for $145 shipped</TD></TR></TABLE>
yea that sinful guy had it on his car, but the lip is not the same. the height of the lip is different. the oem 1 make your car drop 1 inch lower then the jdm ****. plus jdm **** is out of stock. i call them already, they wont be having it til another week or so
if i have a choice. i pick type r over sirg. with 350 more i can get a lip and black housing headlight. instead of buying a type r aftermarket lip, and DIY your paint, which can cause the headlight to fog later on
Thanks guys for the input!!, very helpful on my decision. I have a couple of friends who can get me the front end, not sure yet on a price quote. Most likely get the non hid ones, but the again i can just get the type r with non hid, and just buy aftermarket hids like mculloch or sumtin right? the light output and all, won't look the same but i mean it has projector lights on the non hid's right??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egg6vtak »</TD></TR><TR><TD CLASS="quote">Most likely get the non hid ones, but the again i can just get the type r with non hid, and just buy aftermarket hids like mculloch or sumtin right?</TD></TR></TABLE>if you are going to get an aftermarket HID kit, you might as well spend the money and get the OEM HID front end. just my .02
just get non hid. hid is overrated cop pull your *** over depend on your hid kit also. if is too bright and you cant see **** fixing tix
.. depend on your setup but o well is your money if you can beat 1650 get it, if not pick up from hmo. their **** is clean with complete frotne nd
as a newbie on the type r front end conversion, rating from 1-10 what difficulty should i expect and outcome of it, if i do it myself as a first timer.
