Stock B16 running way to rich...6 mpg????
Old Jun 2, 2006 | 09:02 AM
90jdmcrxdude's Avatar
Default Stock B16 running way to rich...6 mpg????
I did a b16a swap in my 90 crx dx and it started up and runs, however it idles really high at first, and then after it warms up the idle drops way down to almost dying. It is also running really rich, rich enough to coat the back of my car with a film of black unburned fuel. I brough it to mechanics and the only thing that they could figure out was that the O2 sensors were bad and there was a leaky injector. So I changed the O2 sensors and all of the injectors. Then I had the timing checked and that is perfect. The Timing belt was replaced and that timing is good also. I replaced the spark plugs and right after I did that I started it up and then shut it off and checked them and they were all black and covered in carbon. I'm running a PR3 ecu. Does anybody have an idea of wtf could be wrong. I'm sure that somebody has had the same problem. I dont have a fuel pressure regulator, because that would only cover up the problem I want to fix it not cover it up with a fpr or a vafc or something like that.
Old Jun 2, 2006 | 09:06 AM
ZacCarter's Avatar
Your car would have blown up along time ago if you are running this rich and driving the **** out of it, I would try a different ecu.
Old Jun 2, 2006 | 09:12 AM
Default Re: (ZacCarter)
I have a PW0 ecu that does the same exact thing. It also boggs out in lower RPMs and then when it gets to higher rpms it gets better, but it is still alittle jerky when riding at a constant speed.
Old Jun 2, 2006 | 09:16 AM
ZacCarter's Avatar
sounds like a timing issue or and electical issue.
Old Jun 2, 2006 | 09:17 AM
Well the timing is perfect. I dont know where to check for an electrical problems.
Old Jun 2, 2006 | 09:19 AM
ZacCarter's Avatar
did you convert from dpfi to mpfi?
Old Jun 2, 2006 | 09:39 AM
killerformula's Avatar
Default Re: Stock B16 running way to rich...6 mpg???? (90jdmcrxdude)
Are you running an aftermarket fuel pump? have you checked your fuel pressure?
K
Old Jun 2, 2006 | 09:41 AM
sicky's Avatar
grammer nawzi
Default Re: Stock B16 running way to rich...6 mpg???? (killerformula)
why the double post?
https://honda-tech.com/zerothread/1647622
ZacCarter's Avatar
make sure you are running a resitor box if you have the injectors that require it.
Old Jun 2, 2006 | 05:04 PM
I havent changed the fuel pump, its perfect fuel pressure the mechanic checked it. And I need a resisitor box
90jdmcrxdude
57
Jun 7, 2006 08:32 AM
90jdmcrxdude
May 25, 2006 07:49 PM
blackmagicCRX
Oct 17, 2005 05:23 PM
